Author Topic: Vlide Tools/Check Text in Editor  (Read 1367 times)
jlogan02
« on: July 20, 2021, 11:28:53 AM »
When I run "Check Text in Editor" with multiple defuns, is this the result I should expect from the output?
[CHECKING TEXT STA_STD_Conversion.LSP loading...]
; === Top statistic:
; Global variables: (ACDOC CECHO COSMODE EN I OFILEDIA)
; Function definition (with number of arguments): ((*ERROR* . 1) (STA_AE . 0))
; Global variables: (:vlax-true ACDOC ATT2 CECHO CMDECHO DIM OFILEDIA OLAYER OSMODE SSIMAGE X)
; Function definition (with number of arguments): ((*ERROR* . 1) (STA_STD . 0))
; Function definition (with number of arguments): ((C:STA_CONV . 0))
; Check done.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Re: Vlide Tools/Check Text in Editor
« Reply #1 on: July 20, 2021, 12:33:03 PM »
Yes .. localize all those variables.
« Reply #2 on: July 20, 2021, 05:18:51 PM »
This short tutorial may also be of interest.
jlogan02
« Reply #3 on: July 22, 2021, 12:44:03 PM »
Yes indeed.
I did read that tutorial but haven't used the VarList routine. I'll give it a try.
Thanks guys.
J. Logan
ACAD 2018
jlogan02
« Reply #4 on: July 22, 2021, 01:28:10 PM »
Am I using this right?
  1. (defun VarList ( lst )
  2. )
Open my code in Vlide
Put the VarList defun in the code
Run Check Text in Editor
Copy variables from the check
paste (Varlist '(copied variables)) from Check into console
J. Logan
ACAD 2018
« Reply #5 on: July 22, 2021, 04:57:49 PM »
Yes - though, the 'VarList' function is purely for formatting, such that all symbols are presented in lowercase  :-)
