Author Topic: Select the closest line when I click on the text  (Read 2050 times)
emerrryjones
  • Mosquito
« on: July 13, 2021, 10:44:56 PM »
Shark Navigator Lift-Away Deluxe NV360 Review: Is It a Real Steal?
Are you considering buying a Shark NV360 Navigator Lift Away Deluxe professional bagless vacuum? Do you want to know more about it? Check out the review below!
Read More: Shark NV360
Upright Vacuums: Their benefits
Upright vacuum cleaners have some advantages over canister ones for various good reasons. A couple of them are:
  • Usage Suitability
  • One-Time Pass Vacuuming
  • Larger Cleaning Path
  • Good Price
And one of the best uprights should be the Shark Navigator NV360. It is not just well priced but among the most noteworthy items on the leading e-commerce Amazon. The model is additionally moderately lightweight and offers a brilliant vacuuming job of any area that the device is utilized in.
We should check out some of the numerous phenomenal highlights of this unit.
Key Attributes
1. Lift-Away Innovation
It is among the latest Innovations that SharkNinja has made. Thanks to the Lift-Away, you can move the dust canister/ engine assembly out from this upright vacuum cleaner with only a press of a handy button. You have the option to carry the dust canister/ engine assembly using a hand since they utilize the wand/ tools/ hose for vacuuming with the other. That is why this model is a flexible machine that makes it moderately simpler to clean your stairs, collect dust and dirt behind your home furniture, do overhead vacuuming, etc. As it were, it is currently feasible for you to clean pretty much any place without being controlled by the portability of an upright.
2. The Filter
It does not have bags, and you can wash and reuse its filtration system. The advantage of this construction should be - it reduces expenses owing to lacking consumables. The item has two pre-motor filters and a post-motor one.
Other Key Features:
  • Dust cup
  • Crevice Tool
  • Brushroll
  • Big Dustbin
  • Extendable Under-Appliance Wand
  • Pet Hair Collection
  • 25-Foot Electric Cord
  • Never Loses Suction Innovation
A Quick Look at Specifications of Shark navigator NV360
  • 5-year warranty
  • Three in. extension hose with the ability to expand to five in.
  • Engine: 1200 watts, 120 volts, ten amps
  • 25-feet electric cord length
  • Never Loses Suction Innovation delivers a consistent capability of suction
  • Five-inch crevice tool which picks up dust and dirt from crevices and cracks
  • The re washable and reusable filter
  • Anti allergen complete seal technology with the ability to catch and trap dirt and dust
  • The portable detachable canister which makes moving anywhere easier
  • Total weight of the vacuum: 12.5 lb
  • Weight of the canister: 7.5 lb
Pros and Cons
For:
  • Bagless innovation spares time and costs in purchasing bags
  • Can be moved around effortlessly
  • Swivel steering enables more uncomplicated mobility
  • Turn-off and-on option for the brush roll
  • Is moderately quiet
  • The pet hair tool performs extraordinarily in eliminating pet hair and for cleaning stairs
  • Works truly well on floor coverings, tile, and hardwood.
  • Provides an assortment of helpful accessories and tools
  • A convenient Lift-Away attribute for efficiently cleaning any place
  • Flexible, incredible suction on account of the Never Loses Suction Innovation
Against:
  • Longer pet hair may be messed up in the device’s brush roll
  • Can be hard to vacuum your house’s deeper pile carpet
  • May tip over at times of utilizing the hose
  • No headlights
In Short
As should be obvious by the Shark Navigator Lift Away Deluxe Nv360 upright vacuum reviews, the model is doing quite well. Also, in case you need an affordable vacuum with decent vacuuming capacities, this unit may be your best bet!
« Last Edit: March 30, 2022, 11:07:52 AM by emerrryjones »
BIGAL
  • 40 + years of using Autocad
Re: Select the closest line when I click on the text
« Reply #1 on: July 14, 2021, 03:56:42 AM »
Look at this (repeat (setq n (sslength ss))
So you need after selecting the text to do another (repeat (sslength ns)) dont forget closing )
You will need some way of recording which text which line could make another list ( (textentname lineentname) ....   I will let you have a go.
