Author Topic: Draw from Viewport  (Read 957 times)
Coder
Draw from Viewport
« on: July 13, 2021, 09:15:17 AM »
Hello,
Is it possible to draw a few lines for example from a viewport and when I am done, I exit the viewport.
Then the drawn objects moved immediately over the same viewport in the same paper space ?
1- Double click in a viewport to activate it then draw a few lines.
2- Double click outside the viewport to exit then the drawn lines will be moved over the viewport that I used to draw from.
Thank you.
ribarm
  • Marko Ribar, architect
Re: Draw from Viewport
« Reply #1 on: July 13, 2021, 10:28:27 AM »
Draw few lines in Viewport, then use CHSPACE command and select drawn lines, then double click outside Viewport... Lines will be placed in PSpace...
M.R. on Youtube
Coder
« Reply #2 on: July 13, 2021, 11:22:24 AM »
Thank you, that works very well.
« Last Edit: July 13, 2021, 12:56:41 PM by Coder »
