Author Topic: Creating a Routine for Civil3D zoomtosectionview  (Read 3324 times)
MSTG007
« on: June 23, 2021, 03:00:30 PM »
I have been messing around with trying to write a command with the C:zoomtosectionview in it. I am trying to figure how I can ask if I want to have two model tiles or single, then activate the zoomtosectionview command. The below will automatically activate the two tiles.
(defun C:Z2SL () ;Zoom to Sample Line with two model tiles
(setvar "cmdecho" 1)
(ai_tiledvp 2 "_V")
(command "zoomtosampleline")
(command "_AeccStationTrackerAll")
(setvar "cmdecho" 0)
The other question I have, is if the two tiles are activated, it would know not to run that part of the code.
Again, thanks for the ideas and help.
Civil3D 2020
Re: Creating a Routine for Civil3D zoomtosectionview
« Reply #1 on: June 25, 2021, 10:33:13 AM »
  1.       vps (vla-get-viewports doc)
  2.       count (vla-get-count vps)
  3.       )
  4. (if (= 1 count)
  5.   (progn
  6.     ;;only 1 viewport displayed
  7.     )
  8.   (progn
  9.     ;;more than 1 viewport displayed
  10.     )
  11.   )
  12.
  13.
MSTG007
« Reply #2 on: June 25, 2021, 01:17:58 PM »
Thank you Jeff for the direction! Much Appreciated!
Civil3D 2020
