Author Topic: Is there any DES encryption and decryption code implemented by LSP?  (Read 1128 times)
baitang36
Suppose DES is used to encrypt the string in LSP program
d2010
Please,please you do not decrypt .DES files, you do not develope DES-decryptor.exe files, because you lockdown 50%VisualLisp, in entire all internet- market.(e.g.eBay.com, Amazon.com) and Java will be the BEST-of-Best programming language in year2025.
If you wish , the you can encrypted .file directly inside ascii-lisp As js_ldc21. After  you  make programe.DES from js_ldc21.lisp. In this mode, you doubleEncrpyt --> the programe.DES.
 :angel:
« Last Edit: June 23, 2021, 02:10:29 AM by d2010 »
baitang36
Thank you. Do you mean to generate java with LSP? I tried. There was an error in the program and it couldn't be loaded
