Author Topic: Converting 3DSOLIDs to Meshes  (Read 1559 times)
David Bethel
« on: June 22, 2021, 10:03:04 AM »
Morning,
Have they (or anyone ) come up with a decent Solid2Mesh convertor yet ?
Almost every search reverses the keywords to Mesh to Solid
Maybe newer releases have better editing tools
TIA  -David
R12 Dos - A2K
d2010
Re: Converting 3DSOLIDs to Meshes
« Reply #1 on: June 22, 2021, 11:22:33 AM »
Please you upload, the sample.dwg; for more-compatibility you must save
as old-version(e.g autocad 2017) , before you upload it here.
 :gum:
Morning,
TIA  -David
David Bethel
« Reply #2 on: June 22, 2021, 11:33:02 AM »
Thank you,
This came to me in 2004 Format
Regards -David
R12 Dos - A2K
roy_043
  • BricsCAD 18
« Reply #3 on: June 22, 2021, 12:14:13 PM »
There are no 3D solids in the file. But there are regions, which can be produced by exploding 3D solids.
To convert 3D solids you can try the SaveAsR12 command. This will produce PolyFace Meshes from 3D solids and Regions. At least in BricsCAD V18.
David Bethel
« Reply #4 on: June 22, 2021, 12:55:48 PM »
Thanks.  The R12 route creates a wire frame skeleton ( this has been the standard as far back as I remember ) 2004   only  allows DXFOUT option for R12 format.
Maybe I can do a R15 (2000) saveas.
Thanks  Again  -David
R12 Dos - A2K
ribarm
  • Marko Ribar, architect
« Reply #5 on: June 28, 2022, 12:00:42 AM »
This one is for old good time soulmates...
@David, still coding and stuck with CAD?
M.R. on Youtube
