Author Topic: Create custom linetype  (Read 3195 times)
carmi
« on: June 18, 2021, 08:53:42 AM »
Hi all!
I am trying to create a custom linetype.
I created a block, load it on cad program, and created a linetype with this block.
However, I have a problem when drawing with this type of line.
When i draw, i visualize a part of a straight line and only after a while, i visualize my block.
See image attack for better understand me.
Is there a method that allows me to start directly with the block, without straight line?
I attach the block, the linetype and screenshot.
Thank you very much
Lonnie
Re: Create custom linetype
« Reply #1 on: June 21, 2021, 12:42:24 PM »
A,0,[FORMARINGHIERA,formaringhiera,s=1],-1.000
If my memory serves. Problem is your shx file is too long. You are going to have a space on the start and end.
carmi
« Reply #2 on: June 21, 2021, 01:48:12 PM »
its true, there is not the line but there is a space.
I would like it to start where the line starts...as image 2.
can you help me?
Lonnie
« Reply #3 on: June 21, 2021, 02:39:59 PM »
Only by recreating the shx file.
Here is an example for you.
I used the express tools mkshape and mkltype for this. My objects are on 0 and the line is on g-medium.
tombu
  • ByLayer=>Not0
« Reply #4 on: June 23, 2021, 09:30:35 PM »
Try changing the start of the second line of the linetype definition from A to S.
Tom Beauford P.S.M.
