Examples of list:(( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0))((105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0))((105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0))(( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0)) ;<<<<(( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0))(( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0))(( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0))(( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0) ( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0))Each list must give this result:(( 35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) ( 0.0 0.0 0.0) ( 0.0 30.0 0.0) ( 15.0 30.0 0.0) ( 15.0 80.0 0.0) ( 35.0 80.0 0.0))
Marc'(105+30) > (70+50)According to your picture, you proposed wrong vertex for start (it should be IMHO LR - lower right point)...
(defun foo ( l / dl pairs pair pos p ) (setq dl (mapcar '(lambda ( a b ) (distance a b)) l (append (cdr l) (list (car l))))) (setq pairs (mapcar '(lambda ( a b ) (list a b)) dl (append (cdr dl) (list (car dl))))) (setq pair (car (vl-sort (vl-remove-if '(lambda ( x ) (vl-some '(lambda ( y ) (< y 40.0)) x)) pairs) '(lambda ( a b ) (> (+ (car a) (cadr a)) (+ (car b) (cadr b))))))) (setq pos (vl-position pair pairs)) (setq p (nth (1+ pos) (append l l))) (append (member p l) (reverse (cdr (member p (reverse l))))))(princ (foo '((0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0))))(princ (foo '((105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0))))(princ (foo '((105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0))))(princ (foo '((35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0))))(princ (foo '((35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0))))(princ (foo '((15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0) (15.0 30.0 0.0))))(princ (foo '((15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0) (0.0 30.0 0.0))))(princ (foo '((0.0 30.0 0.0) (15.0 30.0 0.0) (15.0 80.0 0.0) (35.0 80.0 0.0) (35.0 30.0 0.0) (105.0 30.0 0.0) (105.0 0.0 0.0) (0.0 0.0 0.0))))
