hi
i was digging the internet from couple of days to find our a lisp to draw an object with a continuous line, since my drawings are always symmetrical Circular Parts with n number of steps in Outer Diameter & inner Diameter, to draw a length is easy just line command & enter length, but to make steps diametrically i have to switch on transparent cal command & type (d1 - d2)/2 for each of the steps which is quite time consuming, & new users who are not use to cal command they use physical calculator for this process
can anybody help me with lisp code so that i just enter the length & next diameter until the last point, also need to generate a center line & mirror the object at the end & connect all the lines of inner diameter
hope my explanation is clear, even though i am attaching an example drawing for a clear picture.
