If you really want to play. You can rename the CUIX to zip and look around. You can also pull out your cui files run it them through the menuload or cui commands to create a mnr file you can edit.
Just sayin. I've heard you should not do it but it's not screwed up on me yet so don't cuss me if you edit your only file and it no longer works. ok?
