Author Topic: OpenDCL - Hello World  (Read 6433 times)
Grrr1337
« on: May 28, 2021, 02:59:03 AM »
Hi guys,
Decided to try out OpenDCL for the first time:
So I've installed "OpenDCL.Studio.ENU.9.1.3.0.msi" successfuly and "OpenDCL.Runtime.9.1.3.0.msi" (not sure if it was installed).
Then I've created a new project - Untitled.odcl with a modeless dialog and two text buttons.
And unfortunately in my ACAD theres no dcl-Project-Import , nor any dcl-* function definition.
My current goal is to run an OpenDCL project from ACAD.
System specifications: Windows 8.1 Pro 64 bit, AutoCAD 2017
Any ideas how could I fix my problem?
(apply ''((a b c)(a b c))
vevo.bg
RGUS
Re: OpenDCL - Hello World
« Reply #1 on: May 28, 2021, 03:44:34 AM »
Yup.... head here and ask the same question.
https://opendcl.com/forum/index.php
Once you get he 'hang' of OpenDCL, there is no going back...
Grrr1337
« Reply #2 on: May 28, 2021, 05:59:28 AM »
Thanks RGUS,
Made a duplicate topic at opendcl.com
I was aware of ODCL for years, but just now decided to try it a bit.
vevo.bg
VovKa
  • Ukraine
« Reply #3 on: May 28, 2021, 05:05:49 PM »
just arxload the corresponding .arx file
Grrr1337
« Reply #4 on: May 29, 2021, 10:43:36 AM »
The problem seems to be that I didn't initially invoked  (command "_OPENDCL"), which loads the library with the dcl-* function definitions.
However it would be cool just to arxload/netload instead of command-calling. :)
I should've checked earlier under "Application Development" section of ODCL's documentation. (Owen answered me anyway)
vevo.bg
roy_043
  • BricsCAD 18
« Reply #5 on: May 29, 2021, 11:10:21 AM »
The general advice is to use the command call. But if you want to make things hard, don't let this stop you.
Grrr1337
« Reply #6 on: May 29, 2021, 06:13:56 PM »
Unfortunately I don't have the time, thought someone already did it.
vevo.bg
