Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
What file format does AutoCAD 2022 use?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What file format does AutoCAD 2022 use? (Read 3210 times)
Custom Title
Seagull
on:
May 12, 2021, 09:53:53 AM »
For some reason that info is not readily available on the Autodesk website.
Thank you!
Logged
TheSwamp.org (
serving the CAD community since 2003
57gmc
Bull Frog
Re: What file format does AutoCAD 2022 use?
Reply #1 on:
May 12, 2021, 10:29:48 AM »
AFAIK it's still the same. To double check, use the SAVEAS command and check the File Type drop down.
Logged
Custom Title
Seagull
Reply #2 on:
May 12, 2021, 10:42:54 AM »
I don't have it installed just yet.
The LT users want to upgrade but I don't want to have file compatibility issues. We do work on the same dwg's at times.
Thanks.
Logged
TheSwamp.org (
57gmc
Bull Frog
Reply #3 on:
May 12, 2021, 11:17:15 AM »
I installed plain acad 2022 on a test vm and created you a test file to try to open in the older versions. Saveas still reports it as a 2018 file type.
Logged
Needs a day job
Reply #4 on:
May 12, 2021, 11:18:33 AM »
It's 2018 version.
Logged
Custom Title
Seagull
Reply #5 on:
May 12, 2021, 11:50:13 AM »
Thank you gentlemen!! I appreciate the info.
Logged
TheSwamp.org (
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
