Author Topic: vla-explode and delay  (Read 4663 times)
domenicomaria
« on: May 09, 2021, 02:41:14 AM »
  1. (defun :SS>OBJECT-LIST (ss / ind r)
  2.    (setq ind 0 r '())
  3.    (repeat (sslength ss)
  4.       (setq r (cons (vlax-ename->vla-object (ssname ss ind) ) r) )      (setq ind (+ 1 ind) )
  5.    )
  6.    (reverse r)
  7. )
  8.
  9.
  10. (defun :VLA-EXPLODE-SS (ss /  new-obj-lst ss-obj-lst x-obj)
  11.    (setq ss-obj-lst (:SS>OBJECT-LIST ss) )
  12.
  13.    (setq new-obj-lst '() )
  14.    (mapcar '(lambda    (x-obj)
  15.                      (if(vlax-method-applicable-p x-obj 'explode)
  16.                         (progn
  17.                            (setq new-obj-lst (append (vlax-invoke x-obj 'explode) new-obj-lst ) )
  18.                            (vla-delete x-obj)
  19.                         )
  20.                      )
  21.             )
  22.               ss-obj-lst
  23.    )
  24.    new-obj-lst
  25. )
  26.
  27.
  28. ;   TEST    asks 2 POINTS
  29. ;         selects with the CROSSING option using these 2 POINTS
  30. ;         and gets the selection 2 TIMES :
  31. ;         BEFORE and AFTER the SELECION has been EXPLODED
  32. (defun c:test ( / ll-pt ss ss1 ss2 ur-pt)
  33.    (setq ll-pt (getpoint "\nLOWER LEFT point :"))
  34.    (initget 32)
  35.    (setq ur-pt (getcorner ll-pt "\nUPPER RIGHT point :"))
  36.    (setq ss1 (ssget "_C" ll-pt ur-pt) )
  37.
  38.    (:VLA-EXPLODE-SS ss1)
  39.    ;   (command "delay" 10)
  40.    (setq ss2 (ssget "_C" ll-pt ur-pt) )
  41.
  42.    (setq r ss2)
  43. )
  44.
  45.
select some polylines, using the TEST function
If (command "delay" 10)   is commented
ss2 is NIL
IF NOT it is a VALID SELECTION SET !
WHY ?
« Last Edit: May 09, 2021, 02:45:11 AM by domenicomaria »
ribarm
  • Marko Ribar, architect
Re: vla-explode and delay
« Reply #1 on: May 09, 2021, 03:56:46 AM »
Try with this simple mod...
(defun c:test ( / ll-pt ss ss1 ss2 ur-pt )
   (initget 1)
   (initget 32)
   (setq ss1 (ssget "_C" ll-pt ur-pt))
   (if (:VLA-EXPLODE-SS ss1)
     (setq ss2 (ssget "_C" ll-pt ur-pt))
   (setq r ss2)
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
« Reply #2 on: May 09, 2021, 04:15:26 AM »
   (initget 1)
   (initget 32)
   (setq r ss2)
I think he wants to have a selection (SS2) even if there are no objects to explode...
Marc'Antonio Alessi
  • Marco
« Reply #3 on: May 09, 2021, 04:19:23 AM »
I removed some local variables and more...
I have tried several times without the DELAY and always I get a selection.
(eq '() nil) => T
(null '())   => T
(not '())    => T
(not nil)    => T
(null nil)   => T
(type '()) => nil
(type nil) => nil
   (setq ind 0)
   (reverse r)
(defun :VLA-EXPLODE-SS (ss / new-obj-lst ss-obj-lst)
                           (vla-delete x-obj)
              ss-obj-lst
   new-obj-lst
(defun c:test ( / ll-pt ss1 ss2 ur-pt)
   (initget 32)
domenicomaria
« Reply #4 on: May 09, 2021, 04:40:25 AM »
yes
domenicomaria
« Reply #5 on: May 09, 2021, 04:42:16 AM »
in acad 2020 ?
without the DELAY, I NEVER get a selection !
domenicomaria
« Reply #6 on: May 09, 2021, 04:43:38 AM »
(eq '() nil) => T
(null '())   => T
(not '())    => T
(not nil)    => T
(null nil)   => T
(type '()) => nil
(type nil) => nil
Why do you post this ?
Marc'Antonio Alessi
  • Marco
« Reply #7 on: May 09, 2021, 05:14:56 AM »
(eq '() nil) => T
(null '())   => T
(not '())    => T
(not nil)    => T
(null nil)   => T
(type '()) => nil
(type nil) => nil
locals are always nil or '()   >>>   (eq '() nil) => T
(setq r '())
Marc'Antonio Alessi
  • Marco
« Reply #8 on: May 09, 2021, 05:19:42 AM »
in acad 2020 ?
A2020:
Command: TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 19>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 20>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 27>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 2e>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 35>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 3c>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 43>
Command:
Command:  TEST
LOWER LEFT point :
UPPER RIGHT point :<Selection set: 4a>
domenicomaria
« Reply #9 on: May 09, 2021, 06:03:24 AM »
(setq r '())
I know that local vars are always NIL.
I write (setq r '()) or (setq new-obj-lst '() )
just to show to myself, that I initializing a new var to nil . . .
But It has no sense ! . . .
domenicomaria
« Reply #10 on: May 09, 2021, 06:26:01 AM »
A2020:
Command: TEST
LOWER LEFT point :
Command:
Command:  TEST
LOWER LEFT point :
Command:
Command:  TEST
LOWER LEFT point :
Command:
Command:  TEST
LOWER LEFT point :
Command:
Command:  TEST
LOWER LEFT point :
Draw 4 or 5 polylines.
Copy them 4-5 times.
And repeat the test . . .
When they are exploded, (ss1 contains only polylines)
ss2 is NIL
If there is no polyline to explode,
ss2 is a selection set.
The problem
(I believe)
is the SEQUENCE
that is NOT RESPECTED.
does NOT WAIT that
(:VLA-EXPLODE-SS ss1) has finished !
If ss1 does not contain EXPLODABLE objects,
needs less time to finish.
And this time is enough.
And
gets the selection set !
It is very strange !
If I enable the DELAY
I get ALWAYS a selection set.
If NOT,
i get a selection set,
only if the selection does not contain explodable objects.
« Last Edit: May 09, 2021, 06:32:39 AM by domenicomaria »
ribarm
« Reply #11 on: May 09, 2021, 07:02:21 AM »
Playing with words...
only if the selection does contain not explodable objects.
M.R. on Youtube
domenicomaria
« Reply #12 on: May 09, 2021, 07:13:37 AM »
If you want change the text
you have to write :
only if the selection does contains not explodable objects.
But this is not the main question.
ribarm
« Reply #13 on: May 09, 2021, 07:32:50 AM »
You want everything to be written for you...
Have you tried :
(defun c:test ( / ll-pt ss1 ss2 ur-pt )
   (initget 1)
   (initget 33)
   (setq r ss2)
M.R. on Youtube
domenicomaria
« Reply #14 on: May 09, 2021, 10:18:06 AM »
only this :
no need of "if"
as in the original code
