Hi All,
Giving Dynamo a try and running into issues on understand how to set points relative to another point or object. see swamp1.jpg.
I'd like to understand if the program has the ability to set points basically by angle and distance from other relative points in the graph that I can later create polygons from.
the goal is to see if I can drive or move the line object and have it recalculate the new points to make the box (see swamp1.jpg), basically it becomes parametric to the lines location.
in the end, I'd like to drive the point parameters from a excel sheet, but that's after I see if I can set points.
Thank you for any help you can provide.
John
