Author Topic: Modifying layers in multiple files at once  (Read 2071 times)
vicoco
  • Mosquito
« on: May 04, 2021, 09:37:37 AM »
Hello everybody,
I'm using a LeeMac AutoLisp, "Copy2Drawing", to copy some objects into a list of drawings in a directory.
I want to extend the code by adding some more functions. But these new functions only work on the current document, and not on the entire collection of drawings .
The new functions would be:
- set layer "0" as the current layer,
- freeze two layers (if they exist) according to some indicated names.
The code I used as follow (unsuccessfully), between highlighted lines (included in an extract from the original AutoLisp file):
  1. (foreach dwg lst
  2.                 (if
  3.                     (or (setq doc (cdr (assoc (strcase dwg) dwl)))
  4.                         (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list dbx dwg))))
  5.                              (setq doc dbx)
  6.                         )
  7.                     )
  8.                     (progn
  9.                         (vla-copyobjects acd var
  10.                             (vla-get-block
  11.                                 (cond
  12.                                     (   (_getitem (vla-get-layouts doc) tab))
  13.                                     (   (vla-add  (vla-get-layouts doc) tab))
  14.                                 )
  15.                             )
  16.                         )
  17.                         ;; New code start
  18.                         (setq LayerTable (vla-get-layers acd))
  19.                         (setq layer0 (vla-item LayerTable 0))
  20.                         (vla-put-activelayer acd layer0)
  21.                         (setq layer1 (vla-item LayerTable "LayerName1")
  22.                                 layer2 (vla-item LayerTable "LayerName2")
  23.                         )
  24.                         (vla-put-freeze layer1 :vlax-true)
  25.                         (vla-put-freeze layer2 :vlax-true)
  26.                         ;; New code finish
  27.                         (vla-saveas doc dwg)
  28.                         (setq cnt (1+ cnt))
  29.                     )
  30.                     (princ (apply 'strcat (cons "\nUnable to interface with file: " (cdr (fnsplitl dwg)))))
  31.                 )
  32.             )
  33.
Note: "layer1" and "layer2" will not always exist. It may be that both exist, only one of them, or that neither exist.
Could you help me about this?
Re: Modifying layers in multiple files at once
« Reply #1 on: May 04, 2021, 12:25:21 PM »
Welcome to TheSwamp :) Try something like this for your layers:
  1. (foreach lyr '("LayerName1" "LayerName2")
  2.   (if (not (vl-catch-all-error-p (setq l (vl-catch-all-apply 'vla-item (list layertable lyr)))))
  3.     (vl-catch-all-apply 'vla-put-freeze (list l :vlax-true))
  4.   )
  5. )
I don't think you can set a current layer via odbx, but could be wrong.
« Reply #2 on: May 04, 2021, 05:45:33 PM »
Correct - the activelayer property is not available for an ObjectDBX document, and neither is the setvariable method unfortunately.
@vicoco, this:
  1. (setq LayerTable (vla-get-layers acd))
Should be:
  1. (setq LayerTable (vla-get-layers doc))
So as to obtain the Layers Collection for the ObjectDBX document as opposed to the Active Document.
vicoco
  • Mosquito
« Reply #3 on: May 05, 2021, 05:21:25 AM »
  4.   )
  5. )
@vicoco, this:
Should be:
Thank you very much to both!!
Because AutoCAD does not allow freezing the current layer, and it's possible that some dwg has one of the layers to freeze as current, I have decided to modify the code, turning the layers off instead of freezing:
  3.     (vl-catch-all-apply 'vla-put-layeron (list l :vlax-false))
  4.   )
  5. )
I am a very beginner in LISP and VL, and I am still learning and understanding many new things every day.
« Reply #4 on: May 05, 2021, 04:20:49 PM »
You can freeze the current layer via DBX  :-)
vicoco
  • Mosquito
« Reply #5 on: May 06, 2021, 04:15:13 AM »
Good point!!
This remark is "freezing" my brain!  :wink:
Thanks again.
cmwade77
« Reply #6 on: May 11, 2021, 07:47:45 PM »
Yikes! That sounds like a recipe for disaster, do you have a way using DBX to check the current layer?
« Reply #7 on: May 11, 2021, 09:40:43 PM »
I do not.
