Author Topic: Draw diagonal hatch lines in rectangle by pick  (Read 7123 times)
Christina
« on: April 14, 2021, 08:35:12 AM »
Hello
Searched for a long time, but not found how I know the four points of a rectangle/square to draw diagonal hatch lines by clicking(pick) somewhere in the rectangle.
The rectangle is made by lines and corners are normally 90°.
If someone can give me a hint how to know the points of the corners by picking anywhere in the rectangle, I will search further to draw the diagonals hatch lines!
I want to thank you in advance for reading this!
I have attach example
Christina
Re: Draw diagonal hatch lines in rectangle by pick
« Reply #1 on: April 14, 2021, 10:31:17 AM »
Welcome to TheSwamp! Here's an example with some comments:
  1. (defun c:foo (/ _boundary e p)
  2.   ;; RJP » 2021-04-14
  3.   ;; Function to get a boundary from a point (bpoly) locks up my session for some reason
  4.   (defun _boundary (p / e)
  5.     (setq e (entlast))
  6.     (command "_.-boundary" p "")
  7.     (if (not (equal e (entlast)))
  8.       (entlast)
  9.     )
  10.   )
  11.   ;; If we have a point and a boundary is created
  12.   (cond ((and (setq p (getpoint "\nPick an internal point: ")) (setq e (_boundary p)))
  13.          (if (= "SOLID" (cdr (assoc 0 (entget e))))
  14.            (alert "Change boundary type to polyline then run the code again...")
  15.            (progn ;; Get the polyline coordinates
  16.                   (setq p (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget e))))
  17.                   ;; Remove our temp boundary
  18.                   (entdel e)
  19.                   ;; Create a line using the first and third point
  20.                   (entmakex (list '(0 . "line") (cons 10 (car p)) (cons 11 (caddr p))))
  21.                   ;; Create a line using the second and fourth point
  22.                   (entmakex (list '(0 . "line") (cons 10 (cadr p)) (cons 11 (cadddr p))))
  23.            )
  24.          )
  25.         )
  26.   )
  27.   (princ)
  28. )
Christina
« Reply #2 on: April 14, 2021, 10:42:46 AM »
OMG - Thank you very much ronjonp!  :smitten:
My day can not be ruined
Christina
« Reply #3 on: April 14, 2021, 10:57:41 AM »
Christina
Glad to help :)
Christina
« Reply #4 on: April 14, 2021, 11:47:48 AM »
RonJon,
Don't know if I can ask another question, but that's the last one!   :oops:
After pick the rectangle, Lisp asks how many divisions I want on the longest side.
If I type 3 the code divides the rectangle into 3 parts and draws diagonal lines in the 3 parts...
Thanks again for your previous code(very happy)!
Christina
« Reply #5 on: April 14, 2021, 12:01:13 PM »
RonJon,
Christina
Post a picture of what you're trying to explain.
Christina
« Reply #6 on: April 14, 2021, 01:08:17 PM »
Thank you for thinking about it !
Christina
Tharwat
  • Hypersensitive
« Reply #7 on: April 15, 2021, 05:48:00 PM »
Here is my attempt for your second request and hopefully Ron won't mind.
  1. ;; https://www.theswamp.org/index.php?topic=56680.new#new
  2. (defun c:Test ( / old new ins lst pt1 pt2 pt3 pt4 tmp div zro prt hor vrt prt 1pt 2pt)
  3.   ;; Tharwat - Date: 16.Apr.2021        ;;
  4.   (and (or (/= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (getvar 'CLAYER)))))))
  5.            (alert "Current layer is locked!. unlock then try again")
  6.            )
  7.        (setq old (entlast))
  8.        (setq ins (getpoint "\nSpecify a point in closed area : "))
  9.        (vl-cmdf "_.-boundary" "A" "O" "P" "" "none" ins "")
  10.        (or (not (equal old (setq new (entlast))))
  11.            (command "_.regen")
  12.            (alert "Invalid point. Try again")
  13.            )
  14.        (progn
  15.          (foreach itm (entget new)
  16.            (and (= (car itm) 10) (setq lst (cons (cdr itm) lst)))
  17.            )
  18.          lst
  19.          )
  20.        (or (and (= 4 (length lst))
  21.                 (setq lst (vl-sort lst '(lambda (j k) (< (car j) (car k)))))
  22.                 (mapcar 'set '(pt1 pt2 pt3 pt4) lst)
  23.                 (or (> (cadr pt2) (cadr pt1))
  24.                     (setq tmp pt1
  25.                           pt1 pt2
  26.                           pt2 tmp)
  27.                     )
  28.                 (or (> (cadr pt4) (cadr pt3))
  29.                     (setq tmp pt3
  30.                           pt3 pt4
  31.                           pt4 tmp)
  32.                     )
  33.                 )
  34.            (and (entdel new)
  35.                 (alert "Invalid polyline was created with more than 4 corners.\nPolyline deleted!")
  36.                 )
  37.            )
  38.        (entdel new)
  39.        (or (initget 6)
  40.            (setq div (getint "\nSpecify number of portions : "))
  41.            )
  42.        (or (and (setq zro (zerop (setq prt (1- div))))
  43.                 (mapcar 'line_ (list pt1 pt2) (list pt4 pt3))
  44.                 )
  45.            (setq hor (distance pt1 pt3)
  46.                  vrt (distance pt1 pt2)
  47.                  prt (/ hor div)
  48.                  )
  49.            )
  50.        (not zro)
  51.        (repeat div
  52.          (setq 1pt (polar pt1 0.0 prt)
  53.                2pt (polar 1pt (* pi 0.5) vrt)
  54.                )
  55.          (mapcar 'line_ (list pt1 pt2) (list 2pt 1pt))
  56.          (or (equal 1pt pt3 1e-4) (line_ 1pt 2pt))
  57.          (setq pt1 1pt pt2 2pt)
  58.          )
  59.        )
  60.   (princ)
  61. (defun line_ (str_ end_) (entmake (list '(0 . "LINE") (cons 10 (trans str_ 1 0)) (cons 11 (trans end_ 1 0)))))
  62.
« Last Edit: April 15, 2021, 07:21:26 PM by Tharwat »
« Reply #8 on: April 15, 2021, 06:08:42 PM »
Good solution Tharwat - just be careful with using the following expression to order the 4 vertices, since if we consider the case of the horizontally oriented rectangle, two pairs of vertices will have the same x-coordinate, and so the order in which such vertices will be sorted is ambiguous - as such, sometimes the diagonal will be pt1-pt4, others it might be pt1-pt3.
Tharwat
  • Hypersensitive
« Reply #9 on: April 15, 2021, 06:16:28 PM »
Thanks Lee,
Yes that might occur so codes updated to account for such circumstances.
« Last Edit: April 15, 2021, 07:20:57 PM by Tharwat »
Christina
« Reply #10 on: April 15, 2021, 08:54:15 PM »
Hello Tharwat and Lee Mac,
Big Thank you for looking into this problem...  :smitten:
We're almost there, the horizontal rectangle works fine.
Looks like there is something about the angles?
My attachment; photo and dwg file will make it more clear.
Christina
Christina
« Reply #11 on: April 15, 2021, 08:57:35 PM »
And the photo
BIGAL
  • 40 + years of using Autocad
« Reply #12 on: April 16, 2021, 12:29:06 AM »
I ran out of time but was taking the approach of pt1-pt4 get vertices,  how many,  then make pt1-1 pt1-2 pt1-3 etc and pt4-1 pt4-2 pt4-3 this way angle of the rectang does not matter. Just make variables as required. Maybe ask Vert or Hor. Make a paired list then play join the dots.
; segment rectangs with verts and X.
; By AlanH April 2021
(defun c:zigzag ( / oldsnap pt pt1 pt2 pt3 pt4 ang1 ang2 dist1 dist2 lst lst2 x y )
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq pt (getpoint "\nPick point inside rectang "))
(command "bpoly" pt "")
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast)))))
(command "erase" (entlast) "")
(setq pt1 (nth 0 co-ord)
  pt2 (nth 1 co-ord)
  pt3 (nth 2 co-ord)
  pt4 (nth 3 co-ord)
  ang1 (angle pt1 pt2)
  ang2 (angle pt4 pt3)
  dist1 (distance pt1 pt2)
  dist2 (distance pt4 pt3)
(setq num (getreal "\Enter number of segments "))
(setq lst '())
(setq lst2 '())
(setq x 1.0)
(repeat (- (fix num) 1)
(setq lst  (cons (polar pt1 ang1 (* dist1 (/ x num))) lst))
(setq lst2 (cons (polar pt4 ang2 (* dist2 (/ x num))) lst2))
(setq x (+ x 1))
(setq lst  (reverse lst ))
(setq lst2 (reverse lst2))
; verts
(setq y 0)
(repeat (length lst)
(command "line" (nth y lst)(nth y lst2) "")
(setq y (+ y 1))
; do ends
(setq y 0)
(command "line" pt1 (nth y lst2) "")
(command "line" pt4 (nth y lst) "")
(setq y (- (length lst) 1))
(command "line" pt2 (nth y lst2) "")
(command "line" pt3 (nth y lst) "")
; do mids
(setq y 0)
(repeat (- (length lst) 1)
(command "line" (nth y lst2) (nth (+ y 1) lst) "")
(command "line" (nth y lst) (nth (+ y 1) lst2) "")
(setq y (+ y 1))
(setvar 'osmode oldsnap)
(c:zigzag)
« Last Edit: April 16, 2021, 01:38:29 AM by BIGAL »
Christina
« Reply #13 on: April 16, 2021, 05:56:36 AM »
Thank you very much Bigal !
When I look at my photo it looks like AutoCad automatically gives pt1, pt2, pt3 and pt4 to the rectangle according to the direction/angle of the rectangle.
Then the length and direction of the rectangle determines how the diagonals should be?
Wow, this seems a very difficult task...
Christina
Tharwat
  • Hypersensitive
« Reply #14 on: April 16, 2021, 06:41:10 AM »
It seems that you want to have the divisions along the longest segment of the closed polyline, so this how I got it from your different examples and hopefully it is the desired one.
  1. (defun c:Test ( / old new ins lst pt1 pt2 pt3 pt4 tmp ang rot zro prt hor vrt prt 1pt 2pt)
  2.   ;; Tharwat - Date: 16.Apr.2021        ;;
  3.   (and (or (/= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (getvar 'CLAYER)))))))
  4.            (alert "Current layer is locked!. unlock then try again")
  5.            )
  6.        (setq old (entlast))
  7.        (setq ins (getpoint "\nSpecify a point in closed area : "))
  8.        (vl-cmdf "_.-boundary" "A" "O" "P" "" "none" ins "")
  9.        (or (not (equal old (setq new (entlast))))
  10.            (command "_.regen")
  11.            (alert "Invalid point. Try again")
  12.            )
  13.        (progn
  14.          (foreach itm (entget new)
  15.            (and (= (car itm) 10) (setq lst (cons (cdr itm) lst)))
  16.            )
  17.          lst
  18.          )
  19.        (or (and (= 4 (length lst))
  20.                 (setq lst (vl-sort lst '(lambda (j k) (< (car j) (car k)))))
  21.                 (mapcar 'set '(pt1 pt2 pt3 pt4) lst)
  22.                 (equal (distance pt1 pt3) (distance pt2 pt4) 1e-4)
  23.                 (or (> (distance pt1 pt3) (distance pt1 pt2))
  24.                     (setq tmp pt2
  25.                           pt2 pt3
  26.                           pt3 tmp)
  27.                     )
  28.                 (or (> (cadr pt2) (cadr pt1))
  29.                     (setq tmp pt1
  30.                           pt1 pt2
  31.                           pt2 tmp)
  32.                     )
  33.                 (or (> (cadr pt4) (cadr pt3))
  34.                     (setq tmp pt3
  35.                           pt3 pt4
  36.                           pt4 tmp)
  37.                     )
  38.                 )
  39.            (and (entdel new)
  40.                 (alert "Invalid polyline was created with more than 4 corners.\nPolyline deleted!")
  41.                 )
  42.            )
  43.        (entdel new)
  44.        (or *div:nums* (setq *div:nums* 3))
  45.        (or (initget 6)
  46.            (setq *div:nums* (cond ((getint (strcat "\nSpecify number of portions < " (itoa *div:nums*) " > : "))) (*div:nums*)))
  47.            )
  48.        (or (and (setq zro (zerop (setq prt (1- *div:nums*))))
  49.                 (mapcar 'line_ (list pt1 pt2) (list pt4 pt3))
  50.                 )
  51.            (setq hor (distance pt1 pt3)
  52.                  vrt (distance pt1 pt2)
  53.                  prt (/ hor *div:nums*)
  54.                  ang (angle pt1 pt2)
  55.                  rot (angle pt1 pt3)
  56.                  )
  57.            )
  58.        (not zro)
  59.        (repeat *div:nums*
  60.          (setq 1pt (polar pt1 rot prt)
  61.                2pt (polar 1pt ang vrt)
  62.                )
  63.          (mapcar 'line_ (list pt1 pt2) (list 2pt 1pt))
  64.          (or (equal 1pt pt3 1e-4) (line_ 1pt 2pt))
  65.          (setq pt1 1pt pt2 2pt)
  66.          )
  67.        )
  68.   (princ)
  69. (defun line_ (str_ end_) (entmake (list '(0 . "LINE") (cons 10 (trans str_ 1 0)) (cons 11 (trans end_ 1 0)))))
  70.
