Author Topic: Help with DoubleOffset lisp - LeeMac Code  (Read 3593 times)
PM
« on: April 10, 2021, 10:42:26 AM »
Hi. I am using LeeMac code for Double offset . I want an update to this code.
I need to select all lines in layer "ROOF-AXIS" and double offset them (0.08m of each side) and the put the offset lines in layer "ROOF"
  1.   (command "_layer" "_m" "ROOF" "_c" "90" "" "")
  2.
  1. (defun c:DOff2 nil (c:DoubleOffset))
  2.
  3. (defun c:DoubleOffset ( / *error* _StartUndo _EndUndo DoubleOffset doc exitflag layer mpoint obj object of point sel symbol value )
  4.
  5.   (defun *error* ( msg )
  6.     (and doc (_EndUndo doc))
  7.     (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
  8.         (princ (strcat "\n** Error: " msg " **")))
  9.     (princ)
  10.   )
  11.
  12.   (defun _StartUndo ( doc ) (vla-StartUndoMark doc))
  13.
  14.   (defun _EndUndo   ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndomark doc)))
  15.
  16.   (defun DoubleOffset ( object offset layer )
  17.     (mapcar
  18.       (function
  19.         (lambda ( o )
  20.           (if
  21.             (and
  22.               (not
  23.                 (vl-catch-all-error-p
  24.                   (setq o
  25.                     (vl-catch-all-apply
  26.                       (function vlax-invoke) (list object 'Offset o)
  27.                     )
  28.                   )
  29.                 )
  30.               )
  31.               layer
  32.             )
  33.             (mapcar
  34.               (function
  35.                 (lambda ( o )
  36.                   (vla-put-layer o (getvar 'CLAYER))
  37.                 )
  38.               )
  39.               o
  40.             )
  41.           )
  42.         )
  43.       )
  44.       (list offset (- offset))
  45.     )
  46.   )
  47.
  48.
  49.   (mapcar
  50.     '(lambda ( symbol value ) (or (boundp symbol) (set symbol value)))
  51.     '(*dOff:Erase *dOff:Layer) '("No" "Source")
  52.   )
  53.
  54.   (if
  55.     (progn
  56.       (while
  57.         (progn
  58.           (princ
  59.             (strcat
  60.               "\nCurrent Settings: Erase source="
  61.               *dOff:Erase
  62.               "  Layer="
  63.               *dOff:Layer
  64.               "  OFFSETGAPTYPE="
  65.               (itoa (getvar 'OFFSETGAPTYPE))
  66.             )
  67.           )
  68.           (initget 6 "Through Erase Layer")
  69.           (setq of
  70.             (getdist
  71.               (strcat "\nSpecify Offset Distance [Through/Erase/Layer] <"
  72.                 (if (minusp (getvar 'OFFSETDIST)) "Through"  (rtos (getvar 'OFFSETDIST))) "> : "
  73.               )
  74.             )
  75.           )
  76.           (cond
  77.             (
  78.               (null of) (not (setq of (getvar 'OFFSETDIST)))
  79.             )
  80.             (
  81.               (eq "Through" of) (setq of (setvar 'OFFSETDIST -1)) nil
  82.             )
  83.             (
  84.               (eq "Erase" of) (initget "Yes No")
  85.
  86.               (setq *dOff:Erase
  87.                 (cond
  88.                   (
  89.                     (getkword
  90.                       (strcat "\nErase source object after offsetting? [Yes/No] <" *doff:Erase "> : ")
  91.                     )
  92.                   )
  93.                   ( *dOff:Erase )
  94.                 )
  95.               )
  96.             )
  97.             (
  98.               (eq "Layer" of) (initget "Current Source")
  99.
  100.               (setq *dOff:Layer
  101.                 (cond
  102.                   (
  103.                     (getkword
  104.                       (strcat "\nEnter layer option for offset objects [Current/Source] <" *dOff:Layer "> : ")
  105.                     )
  106.                   )
  107.                   ( *dOff:Layer )
  108.                 )
  109.               )
  110.             )
  111.             ( of (setvar 'OFFSETDIST of) nil )
  112.           )
  113.         )
  114.       )
  115.       of
  116.     )
  117.     (while
  118.       (progn
  119.         (or ExitFlag
  120.           (progn (initget "Exit")
  121.             (setq sel (entsel "\nSelect object to offset or [Exit] <Exit> : "))
  122.           )
  123.         )
  124.
  125.         (cond
  126.           (
  127.             (or ExitFlag (null sel) (eq sel "Exit")) nil
  128.           )
  129.           ( (vl-consp sel)
  130.
  131.             (_EndUndo doc) (_StartUndo doc)
  132.
  133.             (if (and (wcmatch (cdr (assoc 0 (entget (car sel)))) "ARC,CIRCLE,ELLIPSE,SPLINE,LWPOLYLINE,XLINE,LINE")
  134.                      (setq obj (vlax-ename->vla-object (car sel))))
  135.
  136.               (if (minusp of)
  137.                 (if
  138.                   (progn (initget "Exit Multiple")
  139.                     (and
  140.                       (setq point (getpoint "\nSpecify through point or [Exit/Multiple] <Exit> : "))
  141.                       (not (eq "Exit" point))
  142.                     )
  143.                   )
  144.                   (if (eq "Multiple" point)
  145.                     (while
  146.                       (progn (initget "Exit")
  147.                         (setq mpoint (getpoint "\nSpecify through point or [Exit] <next object> : "))
  148.
  149.                         (cond
  150.                           (
  151.                             (eq "Exit" mpoint)
  152.
  153.                             (if (eq "Yes" *dOff:Erase) (vla-delete obj))
  154.
  155.                             (not (setq ExitFlag t))
  156.                           )
  157.                           (
  158.                             (null mpoint)
  159.
  160.                             (if (eq "Yes" *dOff:Erase) (vla-delete obj))
  161.
  162.                             nil
  163.                           )
  164.                           (
  165.                             (listp mpoint)
  166.
  167.                             (DoubleOffset obj
  168.                               (distance (trans mpoint 1 0)
  169.                                 (vlax-curve-getClosestPointto (car sel) (trans mpoint 1 0) t)
  170.                               )
  171.                               (eq "Current" *dOff:Layer)
  172.                             )
  173.                            t
  174.                           )
  175.                         )
  176.                       )
  177.                     )
  178.                     (progn
  179.                       (DoubleOffset obj
  180.                         (distance (trans point 1 0)
  181.                           (vlax-curve-getClosestPointto (car sel) (trans point 1 0) t)
  182.                         )
  183.                         (eq "Current" *dOff:Layer)
  184.                       )
  185.                       (if (eq "Yes" *dOff:Erase) (vla-delete obj))
  186.                      t
  187.                     )
  188.                   )
  189.                   (setq ExitFlag t)
  190.                 )
  191.                 (progn
  192.                   (DoubleOffset obj of (eq "Current" *dOff:Layer))
  193.
  194.                   (if (eq "Yes" *dOff:Erase) (vla-delete obj))
  195.                 )
  196.               )
  197.               (princ "\n** Cannot Offset that Object **")
  198.             )
  199.            t
  200.           )
  201.         )
  202.       )
  203.     )
  204.   )
  205.   (_EndUndo doc) (princ)
  206. )
  207.
  208.  (princ)
  209.
  210.
Tharwat
  • Hypersensitive
Re: Help with DoubleOffset lisp - LeeMac Code
« Reply #1 on: April 10, 2021, 12:09:20 PM »
Here you go.
  1. (defun c:Test ( / sel int ent )
  2.   ;; Tharwat - Date : 10.Apr.2021       ;;
  3.   (and (or (tblsearch "LAYER" "ROOF")
  4.          (alert "Layer name < ROOF >  was not found in this drawing to continue!")
  5.          )
  6.      (princ "\nSelect lines on layer < ROOF-AXIS > to offset on two sides 0.08 m : ")
  7.      (setq int -1 sel (ssget "_:L" '((0 . "LINE")(8 . "ROOF-AXIS"))))
  8.      (while (setq int (1+ int) ent (ssname sel int))
  9.        (foreach off '(0.08 -0.08)
  10.          (vla-put-layer (car (vlax-invoke (vlax-ename->vla-object ent) 'offset off)) "ROOF")
  11.          )
  12.        )
  13.      )
  14.
PM
« Reply #2 on: April 10, 2021, 12:28:56 PM »
HI Tharwat
I try to change your code to automatic select this lines by is not work !!!
  5.              )
  6.          ;(princ "\nSelect lines on layer < ROOF-AXIS > to offset on two sides 0.08 m : ")
  7.          (ssget "_x" '((0 . "*LINE") (8 . "ROOF-AXIS")))  ; < ----- add this line
  8.          (setq int -1 sel (ssget "_:L" '((0 . "LINE")(8 . "ROOF-AXIS"))))
  9.          (while (setq int (1+ int) ent (ssname sel int))
  10.            (foreach off '(0.08 -0.08)
  11.              (vla-put-layer (car (vlax-invoke (vlax-ename->vla-object ent) 'offset off)) "ROOF")
  12.              )
  13.            )
  14.          )
  15.     (princ)
  16.     ) (vl-load-com)
  17.
  18.
  19.
Tharwat
  • Hypersensitive
« Reply #3 on: April 10, 2021, 12:32:57 PM »
Replace this part from my original posted codes and please modify your post and remove your posted codes.
  1.  (setq int -1 sel (ssget "_X" '((0 . "LINE")(8 . "ROOF-AXIS"))))
Be sure to have the layer ROOF-AXIS unlocked.
PM
« Reply #4 on: April 10, 2021, 12:34:51 PM »
PM
« Reply #5 on: April 10, 2021, 12:42:25 PM »
I want ro ask you some thing else . Is it possible after the offset to fillet 0 all this lines in ROOF layer?
BIGAL
  • 40 + years of using Autocad
« Reply #6 on: April 10, 2021, 09:13:33 PM »
It would be better to make all the joining lines to plines use pedit Join, then run the offset lisp it will auto fillet then.
PM
« Reply #7 on: April 11, 2021, 02:26:45 AM »
Hi Bigal. I use this code to make roof. I did a combination with Tharwat code. My results is in the attach file. I want to trim -extend the offset lines to perimetric roof polylime  and fill with ANSI31 hatch like the attach file.
« Last Edit: April 11, 2021, 02:32:47 AM by PM »
PM
« Reply #8 on: April 11, 2021, 02:34:02 AM »
The ROOF dwg  updated in the previous post
BIGAL
« Reply #9 on: April 11, 2021, 08:43:22 PM »
I think the ridge tops can be filleted by using a circle approach, and checking for a intersectwith, not sure can be automated, may look at making a circle on each end of red lines. The same with eave end it will be a trim or extend. Will have a think about it.
polygon
get co-ord
(setq ss (ssget "F" co-ord '((8 . "ROOF")(0 . "LINE"))))
need to do a distanceatpoint along the polygon via  intersectwith so can sort the line order into pairs then can fillet
« Last Edit: April 11, 2021, 09:01:14 PM by BIGAL »
PM
« Reply #10 on: April 12, 2021, 11:12:19 AM »
can any one fix it?
BIGAL
« Reply #11 on: April 12, 2021, 11:22:04 PM »
Need some time made a start on it be patient.
PM
« Reply #12 on: April 13, 2021, 01:37:20 AM »
Thanks BIGAL
BIGAL
« Reply #13 on: April 15, 2021, 12:30:16 AM »
Sorry took so long had a few other tasks, it only does ridge caps at moment, there is one spot where in you sample it will not work as you have 2 ridges to close so the search polygon gets confused. So just pick the top of the red line. The same method should be able to be used on the eaves.
; fillet offset roof ridges for offset lines equal ridge capping.
; by AlanH April 2021 info@alanh.com.au
(defun AHpllst ( lstpl / x)
(command "_pline")
(while (= (getvar "cmdactive") 1 )
(repeat (setq x (length lstpl))
(command (nth (setq x (- x 1)) lstpl))
(command "")
(defun c:test  ( / oldsnap)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 1)
(while (setq pt (getpoint "\nPick ridge point "))
(setvar 'osmode 0)
;(setq pt2 (getpoint pt "\nPick gap in ridge lines "))
; (setq ang  (angle pt pt2))
(setq ang 0.0)
(setq pi20 (/ (* 2.0 pi) 20.0))
(setq co-ord '())
(repeat 20
(setq pt2 (polar pt (setq ang (+ pi20 ang)) 0.3))
(setq co-ord (cons pt2 co-ord))
(setq co-ord (cons (last  co-ord) co-ord))
(AHpllst co-ord)
(setq obj1 (vlax-ename->vla-object (entlast)))
(setq ss (ssget "F" co-ord '((0 . "LINE")(8 . "ROOF"))))
(setq lst '())
(repeat (setq x (sslength ss))
(setq ent (ssname ss (setq x (- x 1))))
(setq obj2 (vlax-ename->vla-object ent))
(setq pt (vlax-invoke obj2 'intersectWith obj1 acExtendnone))
(setq dist (vlax-curve-getdistatpoint obj1 pt))
(setq lst (cons (list dist pt (cdr (assoc -1 (entget ent)))) lst))
(setq lst (vl-sort lst '(lambda (x y) (< (car x)(car y)))))
(vla-delete obj1)
(setvar 'filletrad 0.0)
(setq x 1)
(setvar 'osmode 512)
(setq x 1)
(repeat (- (/ (length lst) 2) 1)
(setq l1 (entget (nth 2 (nth x lst))))
( setq pt1 (mapcar '* (mapcar '+ (cdr (assoc 10 l1)) (cdr (assoc 11 l1))) '(0.5 0.5)))
(setq l2 (entget (nth 2 (nth (+ x 1) lst))))
( setq pt2 (mapcar '* (mapcar '+ (cdr (assoc 10 l2)) (cdr (assoc 11 l2))) '(0.5 0.5)))
(command "fillet" pt1 pt2  )
(setq x (+ x 2))
(setq l1 (entget (nth 2 (nth 0 lst))))
(setq l2 (entget (nth 2 (last lst))))
(setvar 'osmode 1)
(setvar 'osmode oldsnap)
(c:test)
PM
« Reply #14 on: April 15, 2021, 01:49:40 AM »
Hi BIGAL . Thanks for your time. I try your code but is not working as i expect. Is faster to do filet 0 . Your code create arcs in the roof and became a mess.
Thanks again
