Try this
Excellent solution Stefan
I may be overlooking something obvious, but whilst studying your solution I struggled to understand how the following two expressions determine that the two lines are within the given proximity, independent of the end point used:
Could you shed some light please?
Sure
Each line is defined by an angle
a and the distance
y (signed) from origin.
Angle
a is normalized in range -pi/2...pi/2 in order to match
a and
a+pi.
The distance from origin
y can be calculated analytically given the 2 points defining the line, but I think is to complicated in lisp. For that reason, I uses the Y component of the rotational formula.
Basically, I rotated the line around 0,0 to get a horizontal line, then I got the Y position. Well, you don't need to rotate the entire line, one point is enough because Y is constant in a horizontal line. It could be p2 as well,
The rotational formula, for a point x,y and angle a, counterclockwise (trigonometric), is:
X = x cos(a) - y sin (a)
Y = x sin(a) + y cos (a)
To complicate the things a little bit, the rotation needed is -a; sin (-a) = -sin (a), cos (-a) = cos (a), so Y = - x sin (a) + y cos (a). So it's negative of what I used (to avoid reversing some lists), but it doesn't matter.
The equal function is obvious, it just pairs up 2 lines within a gap d.
