Author Topic: How to store all comments with best variabile-name?  (Read 991 times)
d2010
« on: March 16, 2021, 05:02:45 PM »
I have the source lisp bellow. I want, to store all comments inside variabile name
List or String.I need convert OrgSource To NewSource.
Can you replace "myHelp" with other "namevar" from (C#, Java or Clojure)?
I need import   name from other programmming-language.
 :angel:
(Defun NewSource(lst / $rr p4 p6 mp dx dy dx2 dy2)
      (setq   p5 (acet-geom-list-extents lst)
                myhelp ";p5 and p6 are the geometry points"
              p6 (cadr p5)
              p5 (car p5)
              p5 (list (car p5) (cadr p5))
              p6 (list (car p6) (cadr p6))
              mp (acet-geom-midpoint p5 p6)
              myhelp ";prepare to resize the geometry rectang to"
              dx (- (car p2) (car p1))
             myhelp ";have the same dy/dx ratio as p1 p2."
              dy (- (cadr p2) (cadr p1))
             dx2 (- (car p6) (car p5))
             dy2 (- (cadr p6) (cadr p5))
      );setq
(Defun OrgSource(lst / $rr p4 p6 mp dx dy dx2 dy2)
      (setq   p5 (acet-geom-list-extents lst)              ;p5 and p6 are the geometry points
              p6 (cadr p5)
              p5 (car p5)
              mp (acet-geom-midpoint p5 p6)           ;prepare to resize the geometry rectang to
              dx (- (car p2) (car p1))    ;have the same dy/dx ratio as p1 p2.
      );setq
« Last Edit: March 21, 2021, 06:20:29 PM by d2010 »
BIGAL
  • 40 + years of using Autocad
Re: How to store all comments with best variabile-name?
« Reply #1 on: March 16, 2021, 07:25:13 PM »
(setq myhelp (strcat myhelp "\n" ";the new comment"))
