Author Topic: How to open Excel documents as ReadOnly in Visual-Lisp  (Read 2046 times)
ahankhah
  • Mosquito
« on: March 05, 2021, 06:32:02 AM »
Hi all,
I know the Autolisp functions to open an Excel document:
  1. (defun MT:Open-Excel-File (%ExcelFileName%)
  2.  (vlax-invoke-method (vlax-get-property (vlax-get-or-create-object "Excel.Application") 'WorkBooks) 'Open %ExcelFileName%)
  3. )
But don't know how to open it as ReadOnly.
How is it possible?
I appreciate any help. :smitten:
VovKa
  • Ukraine
Re: How to open Excel documents as ReadOnly in Visual-Lisp
« Reply #1 on: March 05, 2021, 06:52:38 AM »
'Open %ExcelFileName% nil t
ahankhah
  • Mosquito
« Reply #2 on: March 05, 2021, 07:43:57 AM »
Thank you VovKa for your advise. Meanwhile I did "Try and Error" and found same result. The code can be as following:
  2.      (vlax-invoke-method (vlax-get-property (vlax-get-or-create-object "Excel.Application") 'WorkBooks) 'Open %ExcelFileName% nil T)
  3.     )
Again, I appreciate your help.
d2010
« Reply #3 on: March 06, 2021, 02:23:43 PM »
I do not why, the autodesk.forum.lisp, spam  all Topics with Lisp+Microsoft Excel.
If you sharing VLisp+Excel functions/ then you post Copyright-violations, you are enemy of Microsoft-Copyrights?!
If you sharing VLisp+Excel functions/ then you became Hacker.
 :whistling:
« Last Edit: March 06, 2021, 02:26:45 PM by d2010 »
