Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Error: Automation Error. Cannot scale nonuniformly
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Error: Automation Error. Cannot scale nonuniformly (Read 1128 times)
damn
Mosquito
on:
March 01, 2021, 02:04:15 AM »
I'm stumped on this error. In a new drawing session if I open Template "C" and run a layout generator routine I get this error. If I open Template "A" and rerun the routine it works. If Template "A" has been open at any stage during the session it will work. I've pinpointed down to a key viewport that is rezoomed on ea layout. I Haven't written the following code and whilst it mostly works well much of it is poorly documented. I've also pinpointed the code down to this line.
(vla-transformby obj mat)
I realise that's not much help. What possibly could opening another template introduce to prevent the error?
Code expanded.....
Code - Auto/Visual Lisp:
[Select]
foreach
obj
vlax-invoke
setq
doc
vla-get-activedocument
vlax-get-acad-object
'copyobjects
lst
vla-get-block
alay
;;; Code below crashes if Telstra template has not been opened
vla-transformby
obj mat
EDIT (John): Added code tags.
Last Edit: March 01, 2021, 03:11:49 PM by John Kaul (Se7en)
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Error: Automation Error. Cannot scale nonuniformly
Reply #1 on:
March 01, 2021, 08:16:36 PM »
telstra your in AUS
To many unknowns you have 3 variables with no idea of values.
Explain what it is your trying to do.
Logged
damn
Mosquito
Reply #2 on:
March 02, 2021, 05:37:52 PM »
Hi Al, yeah I'm Aus. In short the code is part of a function creating layouts base on the number of frames in the drawing. I haven't tried to figure what this part of the code does as up till now it worked as I always used template A 1st. One of my colleagues discovered when they jumped straight into template C and at 1st I couldn't replicate their problem.
This part of the function zooms on the Key viewport in on the current frame relative to the created to layout and from what I can read it try to sort draw order. Code elaborated, sorry still poorly documented. I realise this probably won't help. I was hoping the scale nonuniformly was common bug.
[Select]
defun
_copyNTSnbn
ob vp lay
acobj acdoc aclay ascc
setq
acobj
acdoc
vla-get-ActiveDocument
acobj
aclay
vla-get-layouts
acdoc
ascc
vla-get-selectionsets
acdoc
alay
vla-item
vla-get-layouts
acdoc
lay
vla-put-activelayout
acdoc
alay
setq
lst
list
ob
vla-put-mspace
acdoc
:vlax-true
vla-put-activepviewport
acdoc vp
setq
mat
vlax-tmatrix
append
mapcar
lambda
a b
append
mapcar
trans
trans
a
0
2
2
3
org
list
b
1.0
0.0
0.0
0.0
1.0
0.0
0.0
0.0
1.0
setq
org
trans
trans
0.0
0.0
0.0
0
2
2
3
0.0
0.0
0.0
1.0
foreach
obj
vlax-invoke
setq
doc
'copyobjects
lst
vla-get-block
alay
vla-transformby
obj mat
vla-put-mspace
acdoc
:vlax-false
setvar
"clayer"
layerNTSGRID
setq
new
ssget
"L"
if
setq
eName
ssname
new
0
progn
vla-getboundingbox
vlax
ename
vla-object
eName
'mn 'mx
vl-cmdf
"._rectang"
vlax
safearray
list
mn
vlax
safearray
list
mx
entdel
eName
setq
pline
vlax
ename
vla-object
ssname
ssget
"L"
0
setq
outerLoop
vlax
make
safearray
vlax-vbObject
0
0
vlax
safearray-put-element
outerLoop
0
pline
setq
hatch
vla-AddHatch
vla-get-block
alay
acHatchPatternTypePreDefined
"ANSI31"
:vlax-True
vla-appendouterloop
hatch outerLoop
vla-put-color
hatch acMagenta
vla-evaluate
hatch
vla-delete
pline
Last Edit: March 02, 2021, 05:46:34 PM by John Kaul (Se7en)
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
