Tested also in 2020 > if the block is not uniform scaled the result of explode is nil ...
I sent the defun Kto a friend of mine, that uses BricsCAD.(I don't know what version)and obj-lst is a list of objects !
(defun c:kkkk () (print (setq x-en (car (entsel)))) (print (setq x-el (entget x-en))) (setq x-obj (vlax-ename->vla-object x-en)) (print (setq v-m-a-p (vlax-method-applicable-p x-obj 'explode))) (print (setq obj-lst (vlax-invoke x-obj "Explode"))) (foreach x-obj obj-lst (print (vla-get-ObjectName x-obj))) (princ)): KKKKSelect entity: <Entity name: 3a719520> ((-1 . <Entity name: 3a719520>) (0 . "INSERT") (5 . "87") (330 . <Entity name: 6ce56170>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 1) (370 . -1) (100 . "AcDbBlockReference") (2 . "arrows8") (10 394.622585423474 58.8644608776229 0.0) (41 . 1.0) (42 . 0.5) (43 . 0.5) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0)) T (#<VLA-OBJECT IAcadHatch2 000000006CE57C00> #<VLA-OBJECT IAcadLine 000000006CE58780> #<VLA-OBJECT IAcadLine 000000006CE58200> #<VLA-OBJECT IAcadLine 000000006CE58C00> #<VLA-OBJECT IAcadLine 000000006CE57D80> #<VLA-OBJECT IAcadEllipse 000000006CE56F80> #<VLA-OBJECT IAcadLine 000000006CE58500> #<VLA-OBJECT IAcadEllipse 000000006CE57300>) "AcDbHatch" "AcDbLine" "AcDbLine" "AcDbLine" "AcDbLine" "AcDbEllipse" "AcDbLine" "AcDbEllipse" : : KKKKSelect entity: <Entity name: 3a7195a0> ((-1 . <Entity name: 3a7195a0>) (0 . "INSERT") (5 . "84") (330 . <Entity name: 6ce56170>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 1) (370 . -1) (100 . "AcDbBlockReference") (2 . "arrows8") (10 390.534090981255 55.2902371436784 0.0) (41 . 0.5) (42 . 0.5) (43 . 0.5) (50 . 5.14332144945154) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0)) T (#<VLA-OBJECT IAcadHatch2 000000006CE57E80> #<VLA-OBJECT IAcadLWPolyline 000000006CE58A80>) "AcDbHatch" "AcDbPolyline" : : KKKKSelect entity: <Entity name: 3a7198e0> ((-1 . <Entity name: 3a7198e0>) (0 . "LWPOLYLINE") (5 . "7F") (102 . "{ACAD_REACTORS") (330 . <Entity name: 3a7198a0>) (102 . "}") (330 . <Entity name: 6ce56170>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (6 . "ACAD_ISO03W100") (62 . 253) (48 . 0.007069650490151) (370 . 25) (100 . "AcDbPolyline") (90 . 7) (70 . 1) (43 . 0.030574411664588) (38 . 0.0) (39 . 0.0) (10 390.884399234151 50.8307665167475) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.0) (91 . 0) (10 390.897503827103 51.1304801628225) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.0) (91 . 0) (10 390.270910292456 50.3143909469705) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.0) (91 . 0) (10 390.831980862344 49.6319119324476) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.0) (91 . 0) (10 390.845085455296 49.9316255785226) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . -0.198303615254713) (91 . 0) (10 391.743449272824 49.3689487916544) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.0) (91 . 0) (10 392.614490304417 50.194350222039) (40 . 0.030574411664588) (41 . 0.030574411664588) (42 . 0.195791166312802) (91 . 0) (210 0.0 0.0 1.0)) T (#<VLA-OBJECT IAcadLine 000000006CE54B50> #<VLA-OBJECT IAcadLine 000000006CE54CD0> #<VLA-OBJECT IAcadLine 000000006CE54E50> #<VLA-OBJECT IAcadLine 000000006CE53F50> #<VLA-OBJECT IAcadArc 000000006CE54250> #<VLA-OBJECT IAcadLine 000000006CE548D0> #<VLA-OBJECT IAcadArc 000000006CE54150>) "AcDbLine" "AcDbLine" "AcDbLine" "AcDbLine" "AcDbArc" "AcDbLine" "AcDbArc"
but not in Acad2020. . .is there no system variableor something such as "initcommandversion"that could change this behaviour ?Or it is a bug ?
