Author Topic: ssget HELP  (Read 934 times)
sln8458
  • CMS Intellicad 9.0/10.0
ssget HELP
« on: February 26, 2021, 10:00:37 AM »
I'm trying to create a selection set of 3Dsolids to be subtracted from another 3dsolid.
First I wanted to a see the selection set move to verify the code.
ALL of the first selection set exist on a new layer HOLES, there is nothing else on this layer.
However i keep getting 'bad argument'
My first attempt was:
(command "move" (ssget "_x" ((0 . "3DSOLID")(8 . "HOLES"))) "0,0,0" "500,0,0")Failed:bad argument
Further reading on the net suggested adding sssetfirst:
(command "move" (sssetfirst nil(ssget "_x" ((0 . "3DSOLID")(8 . "HOLES")))) "0,0,0" "500,0,0")Again failed:bad argument
Any pointers please?
S
There is no such  thing as a 'silly question' to those who do not know!
Re: ssget HELP
« Reply #1 on: February 26, 2021, 10:46:48 AM »
You are missing the quote for the list and the return after getting the selection:
  1. (command "move" (ssget "_x" '((0 . "3DSOLID")(8 . "HOLES"))) "" "0,0,0" "500,0,0")
  2.
sln8458
Re: ssget HELP
« Reply #2 on: February 26, 2021, 11:26:02 AM »
Thanks Jeff
All that head scratching for just a single '  Arhhhh
Plus the ""
