Author Topic: Draw a point with especific distance  (Read 3422 times)
Fabricio28
« on: February 24, 2021, 02:39:20 PM »
How are you?
I'm trying to find a lisp to create a point to 1x1 from specific point.
Anybody could help me please?
Fabricio
Tharwat
  • Hypersensitive
Re: Draw a point with especific distance
« Reply #1 on: February 24, 2021, 03:55:40 PM »
One way with the use of polar function.
  1. (defun c:Test (/ p)
  2.   (or (not (zerop (getvar 'PDMODE))) (setvar 'PDMODE 3))
  3.   (if (setq p (getpoint "\nSpecify a point : "))
  4.     (entmake
  5.       (list '(0 . "POINT")
  6.             (cons 10 (polar (polar p 0.0 1.0) (* pi 0.5) 1.0))
  7.       )
  8.     )
  9.   )
  10.   (princ)
  11. )
  12.
« Reply #2 on: February 24, 2021, 04:42:42 PM »
  1. (defun c:test ( / p )
  2.     (if (setq p (getpoint "\nSpecify point: "))
  3.         (entmake (list '(0 . "POINT") (cons 10 (trans (mapcar '+ p '(1 1)) 1 0))))
  4.     )
  5.     (princ)
  6. )
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: February 24, 2021, 08:45:23 PM »
Perhaps a bit more so X & Y can vary, could add default values if do all the time or as per image.
(setq xy (list  (getreal "\nEnter x ") (getreal "\nEnter Y ")))
        (entmake (list '(0 . "POINT") (cons 10 (trans (mapcar '+ p xy) 1 0))))
Fabricio28
« Reply #4 on: February 25, 2021, 09:22:07 AM »
  4.     (entmake
  7.       )
  8.     )
  9.   )
  10.   (princ)
  11. )
  12.
Thank you very much!!!!
Fabricio28
« Reply #5 on: February 25, 2021, 09:22:39 AM »
  4.     )
  5.     (princ)
  6. )
Mr. Lee Mac
Fantastic!! thanks!!
Fabricio28
« Reply #6 on: February 25, 2021, 09:25:13 AM »
It is very nice!!
input the distance before!! Thanks
Fabricio28
« Reply #7 on: February 26, 2021, 07:45:28 AM »
Hi guys
How are you?
There is not anything wrong about the code.
It is insert a point to x=1 and y=1. But in some case ins't working properly, just like the example bellow:
Fabricio
Tharwat
  • Hypersensitive
« Reply #8 on: February 26, 2021, 07:53:52 AM »
  1. (defun c:Test (/ p d g)
  3.   (and (setq p (getpoint "\nSpecify a point : "))
  4.        (setq d (getpoint "\nSpecify X direction : " p))
  5.        (setq g (angle p d))
  6.        (entmake
  7.          (list '(0 . "POINT")
  8.                (cons 10 (polar (polar p g 1.0) (+ g (* pi 0.5)) 1.0))
  9.          )
  10.        )
  11.   )
  12.   (princ)
  13. )
Fabricio28
« Reply #9 on: February 26, 2021, 08:02:04 AM »
  6.        (entmake
  9.          )
  10.        )
  11.   )
  12.   (princ)
  13. )
Thank you very much for replay
But I have many situation to insert this point. Unfortunately not a default.
maybe if I set the measure x and y (negative or positive) will be great!
Could you help me please?
Tharwat
  • Hypersensitive
« Reply #10 on: February 26, 2021, 08:06:07 AM »
If you have the list of coordinates then you can iterate through each point with angle and distance as I did in my last reply.
Fabricio28
« Reply #11 on: February 26, 2021, 08:11:39 AM »
Sorry if I don't understand what you meant, but I  don't have a list of the coordinates. I'm inserting it manually.
Regards
Tharwat
  • Hypersensitive
« Reply #12 on: February 26, 2021, 08:51:22 AM »
If so then you can specify the angle in the routine as indicated in the codes below and change it to suit yours.
  1. (defun c:Test (/ p g)
  4.        (setq g (* pi 0.25)) ;; = 45 Degree
  5.        (entmake
  6.          (list '(0 . "POINT")
  7.                (cons 10 (polar (polar p g 1.0) (+ g (* pi 0.5)) 1.0))
  8.          )
  9.        )
  10.   )
  11.   (princ)
  12. )
  13.
Fabricio28
« Reply #13 on: February 26, 2021, 09:14:36 AM »
  5.        (entmake
  8.          )
  9.        )
  10.   )
  11.   (princ)
  12. )
  13.
Great!! Thank very much!!
When I changed the angle worked fine!!
Regards
Tharwat
  • Hypersensitive
« Reply #14 on: February 26, 2021, 09:16:14 AM »
You're welcome anytime.
Good luck with your work.
