CAD Forums > CAD General
What does AutoCAD call this...See image
(1/1)
jlogan02:
AutoCAD does a break line when you choose jogged dimension. Or at least that's what I call it.
In the image below what does AutoCAD call a the instance of dimension line that isn't straight?
J. Logan
tombu:
It's just a Leader Line, you can the number of points by clicking Settings.
https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-3351DB2D-FDD5-42AD-981F-782862C524BD
jlogan02:
That's all I could find too, Tom. I was hoping for a variable that would allow me to change the length of the landing next to the text.
tombu:
The length of the landing line for a quick leader is the size of the arrowhead.
For a multileader the gap can be controlled using MLEADERSTYLE click [Modify…] the "Landing Gap" value under 'Leader Structure' tab → Set landing distance.
Navigation
[0] Message Index
Go to full version
