Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
.NET
Topic:
write description for all polyline
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: write description for all polyline (Read 1401 times)
A-SABER
Mosquito
on:
February 05, 2021, 07:36:51 PM »
the folwing code to write polyline name in each polyline the result is the same pic it's ok
I need to write a description for all parcels using code
same like this
PH 101
NORTH ---
SOUTH PH 105
EAST PH 103
WEST ---
anther example
PH 106
NORTH PH 103
SOUT PH 109
EAST PH 106
WEST PH 105
check each parcel if has parcel in north ok write it, not has parcel, not written.
and the same check-in (SOUTH - EAST - WEST )
Code - C#:
[Select]
public
static
void
polylinenumber
double
txth
1
int
snumber
101
Document doc
Autodesk
AutoCAD
ApplicationServices
Application
DocumentManager
MdiActiveDocument
Database db
doc
Database
Editor ed
doc
Editor
using
Transaction trans
db
TransactionManager
StartTransaction
try
BlockTable bt
trans
GetObject
db
BlockTableId
, OpenMode
ForRead
as
BlockTable
BlockTableRecord btr
trans
GetObject
bt
BlockTableRecord
ModelSpace
, OpenMode
ForWrite
as
BlockTableRecord
TypedValue
tv
new
TypedValue
1
tv
SetValue
new
TypedValue
int
DxfCode
Start
"LWPOLYLINE"
0
SelectionFilter filter
new
SelectionFilter
tv
PromptSelectionResult ssPrompt
ssPrompt
ed
GetSelection
filter
if
ssPrompt
Status
PromptStatus
OK
SelectionSet ss
ssPrompt
Value
List
Polyline
lspl
new
List
Polyline
foreach
SelectedObject sObj
in
ss
Polyline poly
trans
GetObject
sObj
ObjectId
, OpenMode
ForWrite
as
Polyline
lspl
Add
poly
var
sortedpolyList
lspl
OrderByDescending
p
p
StartPoint
Y
ThenBy
p
p
StartPoint
X
//var sortedpolyList = lspl.OrderByDescending(p => p.StartPoint.Y).ThenBy(p => p.StartPoint.X);
foreach
Polyline item
in
sortedpolyList
DBText txtpl
new
DBText
txtpl
SetDatabaseDefaults
txtpl
TextString
"PH "
snumber
ToString
//Point3d p2 = PolylineExtensions.Centroid(item);
txtpl
Position
PolylineExtensions
Centroid
item
txtpl
Rotation
0
txtpl
Height
txth
btr
AppendEntity
txtpl
trans
AddNewlyCreatedDBObject
txtpl,
true
snumber
trans
Commit
catch
System
Exception
ex
ed
WriteMessage
"Error pls chek "
ex
Message
trans
Abort
Last Edit: February 13, 2021, 12:40:37 AM by A-SABER
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
.NET
Topic:
