Hi Vikram,
Not sure if the below will work in Progecad, but it uses native commands, so could work.
"If you convert a circle to a polyline and then explode it, you're left with 2 arcs -- a top arc and a bottom arc. If you select both arcs, you can drag the left and right endpoints of those arcs to the points on the circle where you wanted it broken"
