Greetings Everyone,
I'm working on a routine where I need to create a list of "items" (heatpumps) from a text file that is an extract of attruibtes in a drawing. What I want it to do is grab the first item in the just dump it into a list as the first element. Then reading the next line in I want to compare it to the list to see if it's the same, if it is then just skip it. If not append it to the list. Then go to the next line and compare that one to the list. Now that list can be just one or several elements that need to be compared. some of my drawings have over two hundred Heatpumps in them. I'm getting stuck with the comparing and stepping thru the list. any help would be great.
Thanks, Thomas
