Author Topic: AutoCAD command rejected:  (Read 4273 times)
domenicomaria
Re: AutoCAD command rejected:
« Reply #15 on: January 25, 2021, 12:13:55 PM »
Try: create a new UCS >>> WITH NAME then try again (setq *wcs* (vla-get-ActiveUCS *ThisDrawing*))...
Grazie Marco.
Marc'Antonio Alessi
  • Marco
« Reply #16 on: January 25, 2021, 12:48:15 PM »
Grazie Marco.
Prego  :)
domenicomaria
« Reply #17 on: January 27, 2021, 04:27:10 AM »
I understand what the problem is.
I'm trying to create my own MENU, for my commands,
with an OpenDCL palette . . .
So I send to Acad, all the commands, from this menu . . .
But continuosly ACAD says "AutoCAD command rejected: . . ."
The solution is
that I have to set in OpenDCL
the property of the buttons "Event Invoke"
to asynchronicus and
NOT to synchronicus ! ! !
I hope this will help to who will find the same problem !
Thanks to all.
Ciao
d2010
« Reply #18 on: January 27, 2021, 06:46:06 AM »
Does _.ucs command have _origin option?
Can you test the "Expert"-variabile together ?"
(setq vars (list  "CMDECHO")) (mapcar 'setvar vars '(0))
 (command ".expert" (getvar "expert"))  ;; dummy command
 (vl-cmdf "_.pline" "_non" (getpoint)))
domenicomaria
« Reply #19 on: January 29, 2021, 02:19:22 AM »
I took a look to the EXPERT system variable
It can be set to 0 until 5.
But never the UCS command shows the option "origin".
But it exists, works and is HIDDEN.
Marc'Antonio Alessi
  • Marco
« Reply #20 on: January 29, 2021, 07:41:13 AM »
The "origin" request is implied in the prompt itself, probably the option is hidden for a backward compatibility issue…
Nome UCS corrente: *GLOBALE*
Specificare origine dell'UCS o [Faccia/con NOme/OGgetto/Precedente/Vista/Globale/X/Y/Z/Asse-z] <Globale>: _origin
Specificare nuovo punto di origine <0,0,0>:
BricsCAD
: UCS
Specify origin of UCS or [Face/NAmed/Entity/Previous/View/X/Y/Z/Z Axis/Move/World] <World>:_origin
Origin point <0,0,0>
domenicomaria
« Reply #21 on: January 29, 2021, 08:36:51 AM »
yes
it is so
