Author Topic: Reload Xref  (Read 1404 times)
RolandOrzabal
  • "memories fade but the scars still linger"
Reload Xref
« on: January 18, 2021, 08:29:26 PM »
Hi All,
Our project number was recently change so it means renaming all the files and by doing so, all xref needs to be reloaded.
So from, let's say x-12345-xxxxx.dwg, it became x-54321-xxxx.dwg.
Renaming the files is easy, Files are still in the same location. But needs to be be reloaded one by one.
Reference Manager doesn't help coz names were change.
I have hundreds of drawing to reload and lots of xref in each drawing.
Do you guys know any faster work around?
« Last Edit: January 18, 2021, 08:33:49 PM by RolandOrzabal »
RlordCAD
  • Mosquito
Re: Reload Xref
« Reply #1 on: April 02, 2021, 12:04:29 AM »
Use the command REDIR
OLD PATH↩️
NEW PATH↩️
kruuger
Re: Reload Xref
« Reply #2 on: April 02, 2021, 06:04:44 AM »
OLD PATH↩️
NEW PATH↩️
this will not work. he needs to update the file names.
https://jtbworld.com/jtb-fixrefs -> worth every single penny.
kruuger
