Author Topic: WPF or Windows Forms  (Read 2196 times)
Augusto
« on: January 08, 2021, 06:15:57 AM »
Assuming your application needs forms and palettes, what do you consider best for development, WPF or Windows Forms?
I'm still giving my first steps in C#, doing some tests. If possible I would like to know your point of view on these technologies as pros and cons, reasons to use or not.
In addition, I have other doubts regarding the behavior of these components in different environments, such as a computer whose font scale is different from 100%.
Looking at this example on the Kean website, I could see that it creates and changes a palette referencing Windows Forms components.
https://www.keanw.com/2015/09/creating-an-autocad-palette-dynamically-to-launch-commands-and-methods-tagged-using-net.html
huiz
  • Certified Prof C3D
Re: WPF or Windows Forms
« Reply #1 on: January 08, 2021, 01:20:57 PM »
Winforms is a bit easier and if you scale the form with DPI instead of Font, it will scale not really bad on 4K.
WPF is a b*tch and you'll start to hate it real quickly but it is a much better choice. I will never return to WinForms. You can do so many great things when you have more experience.
gile
  • Marseille, France
« Reply #2 on: January 09, 2021, 05:01:01 AM »
You can have a look to this modest contribution about user interfaces with AutoCAD .NET.
themethodman
  • Mosquito
« Reply #3 on: January 10, 2021, 05:38:57 PM »
I've used winforms in the past due to its simplicity.
My user interfaces aren't complicated so I followed the keep-it-simple-stupid approach.
They also fit nicely in with most of autocads own user interface menus as well.
Augusto
« Reply #4 on: January 13, 2021, 09:37:20 AM »
Thinking about avoiding problems in my first project, I will consider using WPF in the next time.
Excellent tutorial!
I will definitely revisit it in the future.
Thank you for sharing your knowledge.
Even though I know that WPF increases the possibilities of personalization, I will use Windows Forms because I am used to its use in applications outside of autoCAD.
I believe that this way my performance will be better initially. I hope I'm not mistaken.
Thank you all for the answers.
