Author Topic: Tool for displaying / handling dictionaries?  (Read 438 times)
Peter2
« on: January 07, 2021, 06:22:46 AM »
Is there a tool for a simple display (or handling?) dictionaries? Like the name, the size, the content? The "ArxDbg Utility" covers a part of this functions, but shows mainly the "database background" and not the user-side ...
Peter
AutoCAD Map 3D 2018 German (so some technical terms will be badly retranslated to English)
BricsCAD V19
BIGAL
  • 30 + years of using Autocad
Re: Tool for displaying / handling dictionaries?
« Reply #1 on: January 07, 2021, 06:06:19 PM »
Your question is a bit vague what is it your trying to do, look inside  a dictionary.
This shows how to look for a dictionary name. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/listing-dictionaries/td-p/1522830
a example
(defun GetKVPairs (e / return xD esriD att key val)
;Get Key/Value Pairs
(setq return '())
(if (and (setq xD (cdr (assoc 360 (entget e))))
(setq esriD (cdr (assoc -1 (dictsearch xD "ESRI_ATTRIBUTES")))))
    (setq att (entget esriD))
    (while (setq att (member (assoc 3 att) att))
      (setq key (cdr (car att))
    val (cdr (assoc 1 (entget (cdr (car (setq att (cdr att))))))))
      (setq return (cons (cons key val) return))
    );while
    (setq return (reverse return))
  );progn
;else
  (setq return nil)
);if
return
);defun
« Last Edit: January 07, 2021, 06:11:29 PM by BIGAL »
Peter2
« Reply #2 on: January 10, 2021, 12:53:24 PM »
@BIGAL
thanks, works fine for me.
Peter
BricsCAD V19
dgorsman
« Reply #3 on: January 12, 2021, 01:51:08 PM »
I've normally used the VLIDE, through the watch window.  Sometimes dumping results to the log.  A bit primitive maybe, but gets the info I need.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
