Author Topic: How to merge two vlx files into one?  (Read 1441 times)
baitang36
« on: December 31, 2020, 11:06:46 PM »
I can merge Fas file, very simple.
Run cmd.exe
copy 1.fas + 2.fas 3.fas /b
But this method is not good for vlx, and can not run after merging
I succeeded in the experiment. See the attachment for the procedure
Loading this LSP will generate an EXE file in D: \. There is no virus. Please select trust.
« Last Edit: January 04, 2021, 09:04:30 PM by baitang36 »
d2010
Re: How to merge two vlx files into one?
« Reply #1 on: January 01, 2021, 08:08:22 AM »
Other method..you extract all files.fas from both-progn.vlx, and you merge all-files.fas to big-new-project.vlx + big-new-project.prj isInside anyAutoCAd.
RE: It is a mature technology to decompile Fas
into LSP. I have decompiler tools in my hand.
« Last Edit: January 10, 2021, 07:00:35 AM by d2010 »
baitang36
« Reply #2 on: January 01, 2021, 09:42:45 PM »
Change vlx to LSP and recompile with vlide? It can be done, but it's more troublesome
baitang36
« Reply #3 on: January 04, 2021, 09:05:01 PM »
