Can I add another one ...
User opens drawing does not change anything simply opens the drawing ....
Click that little [X] in the corner ...
"Save changes to <drawingname>?"
Oh and I'm still pissed that Autodesk has effectively revoked my legally acquired AutoCAD license.
This one may or may not be blamed on Autodesk. It could be a bug introduced by later version of AutoCAD, but I have not run into it. Rather I am sure many custom add-in applications loaded into AutoCAD on its start-up would result in this (i.e. somehow the drawing's DBMOD being changed), including many CAD applications I wrote
![tickedoff :tickedoff:](http://www.theswamp.org/Smileys/black/tickedoff.gif)
So, you could try to run plain AutoCAD with absolutely no custom app (VBA/LISP/.NET/ARX) loaded on startup and then close AutoCAD immediately to see if it happens or not. If not, it is the other Cad app causes the issue.
