Author Topic: DCL - restore previous values  (Read 1256 times)
DraxJDM
« on: December 23, 2020, 04:25:18 AM »
Hey all,
I am trying to find my way in DCL forms.
so far I have managed to put something together with the help of information on afralisp and an example from Lee Mac.
i have multiple problems   :-(
in the dcl, i  would like to get the label above the text field
i can set a default for the color
I can't get back the chosen values ​​when I restart the routine for the part .
for the code to work you have to upload lee mac  - ListTileDependencyV1-1.lsp
found at his website -  http://www.lee-mac.com/listtiledependency.html
;; Two List Tile Dependency Example  -  Lee Mac
;; Requires ListTileDependency.lsp to be loaded.
(defun c:test1_a5 ( / *error* dch dcl des lst )
  ;; rtn
 ;;; end subroutine
    (defun *error* ( msg )
        (if (= 'file (type des))
            (close des)
        (if (< 0 dch)
            (unload_dialog dch)
        (if (and (= 'str (type dcl)) (findfile dcl))
            (vl-file-delete dcl)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
            (princ (strcat "\nError: " msg))
   (setq lst
     ("German"
   ("Audi"    ("TTS Quattro" "TT RS" "S3 Quattro" "S4 Quattro" ))
   ("BMW"     ("M3" "M5" "M6" "X5" "Z3" "Z4"))
   ("Porsche" ("911" "924" "928" "930" "944" "Boxster" "Cayenne" "Cayman"))
     ("English"
     ("Jaguar"  ("XF" "XJ6" "XJR" "XKR" "X-Type" "S-Type"))
     ("Bentley"  ("Cintinental" "Flying Spur" "Mulliner" "Bentayga" ))
  ;; list colr
  (setq lst-Color (list "Blue" "Red"))
;;; end lists
     ; Set Default Variables
  (if (not *MyPopupLists@);Unique global variable name to store dialog info
    (setq *MyPopupLists@ (list nil "" ""))
  );if
  ;(setq lst-color-value (nth 1 tmp.dcl))
        (and
            (setq dcl (vl-filename-mktemp "tmp.dcl"))
            (setq des (open dcl "w"))
            (foreach str
                    "lbx : list_box"
                    "    alignment = centered;"
                    "    fixed_width = true;"
                    "    fixed_height = true;"
                    "    width = 20;"
                    "    height = 15;"
    "ebx : edit_box"
     ;; key = "Edit1";//Edit1$ from lsp file
                    "    width = 20;"
                    "test : dialog"
                    "    label = \"List Box Dependency Example\";"
                    "    spacer;"
                    "    : row"
    "        : lbx { key = \"lb1\"; label = \"List Box 1\"; }"
    "        : ebx { key = \"ebx2\"; label = \"text box 2\"; }"
                    "        : lbx { key = \"lb3\"; label = \"List Box 3\"; }"
                    "        : lbx { key = \"lb4\"; label = \"List Box 4\"; }"
    "        : lbx { key = \"lb5\"; label = \"List Box 5\"; }"
                    "    spacer;"
                    "    ok_cancel;"
                (write-line str des)
            (not (setq des (close des)))
            (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "test" dch)
  ;; if there was a choice
  ;; return
  (if rtn
    (setq rtn rtn)
            (setq rtn '(0 0 0))
  ;; color
  (if color-2
    (setq color-in color-2)
            (setq color-in 0)
  ;; number-ok
          (if number
    (setq number (rtos (fix number)))
            (setq number "12345")
            (LM:dcld:action '("lb3" "lb4" "lb5") 'lst 'rtn)
  ;; add the lst-Color
  ;;(set_tile "lb1" color-in)
  (start_list "lb1") ;start the list box
  (mapcar 'add_list lst-Color) ;fill the list box
  (end_list) ;end list
  ;; add the text field -nummer
  (set_tile "ebx2" number)            ; value
    (action_tile "eb1"       ;is user enters
"(ebox_action $value $reason)")      ;pass arguments to ebox_action
   (action_tile
    "accept" ;if O.K. pressed
    (strcat ;string 'em together
      "(progn
      (setq return (LM:dcld:getitems rtn lst))
       (setq Color (atof (get_tile \"lb1\")))"         ;get list selection
      "(setq lngth (atof (get_tile \"ebx2\")))" ;get slot length
      " (done_dialog)(setq userclick T))" ;close dialog, set flag
    );strcat
  );action tile
       (if (= 1 (start_dialog))
;; als is oke
      ;(setq return (LM:dcld:getitems rtn lst))
); end progn  - als is oke
(princ "\n*Cancel*")
            ); end if dialog
  ); end progn
    ); end if
;;;       (setq return (LM:dcld:getitems rtn lst))
      ;(setq SIZ-1 (atof (get_tile "lb1")))
              (setq color-2 (fix color)) ;convert to integer
              (setq color-3 (nth color-2 lst-Color)) ;get the size
    (setq number (fix lngth))
    (*error* nil)
