Author Topic: Automatic indenting fix tool  (Read 1430 times)
w64bit
« on: December 11, 2020, 07:39:56 AM »
I am very new to LISP and I want to know if there is any tool to automatically fix indenting in existing lsp files (not something like parinfer when writing new code).
I am asking this because the content in some of my files is left aligned.
It seems I am asking too much but I want some order in my files and I think I'll learn faster if I first I can correct the indenting of my existing code.
Maybe there are several ways to indent lisp code but I'll take any simpler method you can suggest.
Thank you very much
kirby
Re: Automatic indenting fix tool
« Reply #1 on: December 11, 2020, 07:53:44 AM »
See the ancient lisp beautifier tool lb.exe
http://www.theswamp.org/index.php?topic=37924.0
You'll need to use DOSBox to run it
https://www.dosbox.com/
w64bit
« Reply #2 on: December 11, 2020, 11:46:43 AM »
Thank you very much.
PKENEWELL
« Reply #3 on: December 11, 2020, 02:54:37 PM »
Why not just load it into the Visual LISP Editor and use the "Format code in Editor" under the "tools" menu?
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
« Reply #4 on: December 11, 2020, 03:33:25 PM »
Or in VS Code: <Ctrl-k Ctrl-f>
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: December 12, 2020, 04:00:13 AM »
Or in Bricscad BLADE (Reformat Beautify)
w64bit
« Reply #6 on: December 12, 2020, 11:54:38 AM »
Beautiful!
