Dear other autocad users, I am coming to you with what is probably the dumbest issue in existence but here it is. I'm having plotter issues and our IT is of no help.
I usually work by setting up my layout and Page Setup, most often with a custom paper size. The problem is that our HP printer only takes 10 custom paper sizes until I get the message "you have reached the limit of 10 exportable custom sizes". I used to ignore this and save more custom page sizes but at some point the driver just conked out and wouldn't plot anything and required re-install on my machine.
Now I'm trying to avoid this issue, but even if I try to standardise my drawings that's still more than 10 custom sizes that I need. I tried having multiple pc3 named HP_plotter_1 and HP_plotter_2 each with <10 custom paper sizes. But when I tried modifying the paper sizes in one pc3 file it also modified them in all the others for the same HP_plotter. And how do I make sure that someone else in the office can also easily print drawings I made?
