Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help with a lisp : Lenght Of Object
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help with a lisp : Lenght Of Object (Read 1392 times)
PM
Guest
on:
December 06, 2020, 03:21:26 AM »
I have this code to dimension lines. arc,polylines . The problem is that calculate the full length. So when i have 4 points on an arc or on a polyline i can not find the distance between them. I want to ask if it possible to make this lisp work like this
1) select the object (so understand if it is a polyline ,or line or acr etc...)
2) give as the otion to hit ender and calculate all the distanse or
3) give as the option to pick 2 points and aclulate the dinstanse from this area only
Code - Auto/Visual Lisp:
[Select]
defun
LenghtOfObject
obj
len
if
vl-catch-all-error-p
setq
len
vl
catch
all
apply
vlax-curve-getDistAtParam
list
obj
vl
catch
all
apply
vlax-curve-getEndParam
list
obj
nil
len
;------------------------------------------------ c:LengthText ----------------
defun
c:LineDimAnnot
ModelSpace
sel
command
"_.-layer"
"_make"
"_dimension"
"_color"
93
"_lweight"
0.30
command
"_.-style"
"_diast"
"wgsimpl.shx"
"_annotative"
"_yes"
"_no"
1.75
1.0
0.0
"_no"
"_no"
"_no"
vl-load-com
setq
ModelSpace
vla-get-ModelSpace
vla-get-ActiveDocument
vlax-get-acad-object
setvar
"errno"
0
; when the user on ssget press Enter the errno is set to 52
while
and
setq
sel
ssget
getvar
"errno"
52
if
sel
progn
mapcar
function
lambda
ent
obj olg stpt endpt next_pt midpt TxtObj midpt1
setq
Obj
vlax
ename
vla-object
ent
if
and
setq
olg
LenghtOfObject obj
olg
0
progn
setq
stpt
vlax-curve-getStartPoint
obj
setq
endpt
vlax-curve-getendpoint
obj
setq
midPt
vlax-curve-getPointAtDist
obj
olg
0.5
setq
midPt1
polar
midPt
0.5
pi
angle
stpt endpt
1e
3
setq
TxtObj
vla-addText
ModelSpace
rtos
olg
2
2
vlax-3d-point
midpt
1
getvar
'cannoscalevalue
1.75
;_ end of vla-addText
vla-put-Rotation
TxtObj
1.5
pi
angle
vlax-curve-getClosestPointTo
obj midpt1
midpt1
setq
midpt
vla-get-InsertionPoint
TxtObj
vla-put-alignment
TxtObj acAlignmentBottomCenter
vla-put-TextAlignmentPoint
TxtObj midpt
if
ssmemb
ent sel
ssdel
ent sel
vl
remove
if
not
lambda
x
type
x
'ENAME
mapcar
cadr
ssnamex
sel
;change layer to 0
mapcar
setvar
clayer cecolor celtype celweight
list
"0"
"BYLAYER"
"BYLAYER"
1
princ
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Help with a lisp : Lenght Of Object
Reply #1 on:
December 07, 2020, 01:29:23 AM »
Over at forum\autodesk kent1cooper has some very good dim pline etc may be what your looking for.
Logged
JarvisDashiell
Mosquito
Reply #2 on:
December 17, 2020, 11:34:33 PM »
Logged
แทงบอล
ดูบอลสดฟรี
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
