Author Topic: Linetype Understanding  (Read 3369 times)
MSTG007
« on: December 03, 2020, 05:33:39 PM »
I am bashing my head, and cannot figure how to get this polyline to show correct spacing with the linetype.
*FP,FIRE  FP --------- FP ---------
A,.6,-.09,["FO",STANDARD,S=.06,U=0.0,X=-0.0825,Y=-.03],-.09
Can you elaborate why it is working like this and how to fix it lol.
Thank you!
Civil3D 2020
Re: Linetype Understanding
« Reply #1 on: December 03, 2020, 08:38:01 PM »
Change the X value to -.045 (half the length of the space)
MSTG007
« Reply #2 on: December 04, 2020, 07:34:55 AM »
Thanks Jeff for the response... That worked great!
Im still drawing a blank on ones that contain single and triple values.
*ELEC,ELEC  --------- E ---------
A,.6,-.06,["E",Standard,S=.06,U=0,X=-0.045,Y=-0.03],-.06
*ETC,ETC --------- ETC ---------
A,.6,-.12,["ETC",Standard,S=.06,U=0,X=-0.065,Y=-0.03],-.12
Civil3D 2020
« Reply #3 on: December 04, 2020, 11:40:25 AM »
You just need to adjust the X value based on the width of the characters being used. This can vary depending on the font in the style. This appears to work with Standard style using the txt.shx font.
A,.6,-.06,["E",Standard,S=.06,U=0,X=-.02,Y=-0.03],-.06
A,.6,-.12,["ETC",Standard,S=.06,U=0,X=-0.08,Y=-0.03],-.12
« Reply #4 on: December 04, 2020, 01:00:53 PM »
The base insertion point for text in a linetype is the lower left corner. So the Y value of a 0.06 high character is -0.03 (as your definitions all show).To easily calculate the X value, create a Dtext of the desired text at the desired height, using a justification of MiddleCenter. Subtract the the 2 X values shown in the text object properties and use the negative value in the LT definition X value.
MSTG007
« Reply #5 on: December 04, 2020, 04:03:43 PM »
Thanks again Jeff! much Better!
Civil3D 2020
« Reply #6 on: December 04, 2020, 05:00:18 PM »
Also do a search for 'makelt' takes the guess work out of it  8-)
MSTG007
« Reply #7 on: December 05, 2020, 02:45:23 PM »
lol. I should have known to just look. lol Thanks again Ron! Nice Routine. handy;)
Civil3D 2020
« Reply #8 on: December 07, 2020, 01:12:49 PM »
Glad to help :)
http://www.theswamp.org/index.php?topic=47058.msg520876#msg520876
MSTG007
« Reply #9 on: December 08, 2020, 07:15:12 AM »
Your a MANIAC. Nice GUI. A lot easier. Again thank you for sharing that link. Helps ALOT!
Civil3D 2020
