Your LISP has been simplified a lot, let me learn a lot thanks
My LISP can only have one choice, yours can have multiple choices
On this basis, I added a round LISP,
how to modify it to Multiple choice in multiple closed graphics?
Multiple choices like the photo below
(defun c:ss()
(setq cmd (getvar "cmdecho"))
(setq osm (getvar "osmode"))
(setvar "cmdecho" 0)
(command "undo" "be")
(If (progn
(princ "select:")
(setq ssa (ssget":S" '((0 . "lwpolyline"))))
(setq dxf (entget (ssname ssa 0)))
(setq pts (mapcar 'cdr (vl-remove-if '(lambda(x)(/= (car x) 10)) dxf)))
(setq p1 (apply 'mapcar (cons 'min pts)))
(setq p3 (apply 'mapcar (cons 'max pts)))
(setq p2 (list (car p3) (cadr p1)))
(setq p4 (list (car p1) (cadr p3)))
(setq p14m1 (mapcar '(lambda(a b)(* 0.5 (+ a b))) p1 p4))
(setq p14m2 (mapcar '+ p14m1 '(5 0)))
(setq p12m1 (mapcar '(lambda(a b)(* 0.5 (+ a b))) p1 p2))
(setq p12m2 (mapcar '+ p12m1 '(0 5)))
(setq p23m1 (mapcar '(lambda(a b)(* 0.5 (+ a b))) p2 p3))
(setq p23m2 (mapcar '+ p23m1 '(-5 0)))
(setq p34m1 (mapcar '(lambda(a b)(* 0.5 (+ a b))) p3 p4))
(setq p34m2 (mapcar '+ p34m1 '(0 -5)))
(setvar "osmode" 0)
(mapcar '(lambda(pts)
(command "_line" (car pts) (cadr pts) "" "_chprop" (entlast) "" "c" 1 "")
(list (list p14m1 p14m2)
(list p12m1 p12m2)
(list p23m1 p23m2)
(list p34m1 p34m2)
(mapcar '(lambda(pt dxy)
(setq pt1 (mapcar '+ pt dxy))
(command "_Circle" pt1 1.55 "_chprop" (entlast) "" "c" 1 "")
(command "_Circle" pt1 1.80 "_chprop" (entlast) "" "c" 1 "")
(list p1 p3 )
(list '(8 8) '(-8 -8))
(command "_Circle" pt1 1.50 "_chprop" (entlast) "" "c" 1 "")
(list p2 p4 )
(list '(-8 8) '(8 -8))
(command "undo" "e")
(setvar "osmode" osm)
(setvar "cmdecho" cmd)
