Glad to help .. you can also use an association list like so:
[code
=cadlisp
-7](if (setq sel1
(ssget "_X" '
((0 .
"MULTILEADER")))) ;;multi-leader
This last bit is exactly it. It's an instance of, if you don't lisp enough you forget crap. I'm working on "sister" code that goes along with this one and have encountered the same issue with the names. This will definitely help.
I have questions on that lisp, but will create a separate post for it. Actually, I think one of the examples I'm using is from you.
Thanks again.
