I have a set of blocks for different size bolts which I insert from a pull down menu. The method is described below.
I wanted to have a way that I could input what length the bolt should be.
Can this be done?
It doesn't sound easy as most lines/arcs stay the same but some change in length.
METHOD
A file exists for each block (M6.dwg, M8.dwg, M10.dwg, etc).
These CAD files, a script file and menu file (see code below) are all placed in one folder.
Then the script file is run from AutoCAD to generate the menu.
Then go to menu, choose a block and it's inserted.
SCRIPT FILE (.scr extension)
(if (and (not (findfile "STEEL.mnu"))
(findfile "C:\\Pull down menu\\POP12 Steel\\STEEL.mnu")
(setenv "ACAD" (strcat (getenv "ACAD") "C:\\Pull down menu\\POP12 Steel"))
(command "._MENULOAD" "STEEL.mnu")
(menucmd "P12=+STEEL.CTOPopSTEEL")
MENU FILE (.mnu extension)
***MENUGROUP=STRUCTURAL_STEEL
***POP12
**CTOPopSTEEL
[Steel]
[->Bolts]
[M6]^C^C(BlockInsert "Bolts_M6");scale;1;
[M8]^C^C(BlockInsert "Bolts_M8");scale;1;
[M10]^C^C(BlockInsert "Bolts_M10");scale;1;
[M12]^C^C(BlockInsert "Bolts_M12");scale;1;
[M16]^C^C(BlockInsert "Bolts_M16");scale;1;
[M20]^C^C(BlockInsert "Bolts_M20");scale;1;
[M24]^C^C(BlockInsert "Bolts_M24");scale;1;
[M30]^C^C(BlockInsert "Bolts_M30");scale;1;
[<-M36]^C^C(BlockInsert "Bolts_M36");scale;1;
