Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Multiple MText entities with varying overridden colors back to Bylayer
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Multiple MText entities with varying overridden colors back to Bylayer (Read 1108 times)
jlogan02
Bull Frog
on:
November 17, 2020, 12:26:40 PM »
I have multiple instances of mtext notes that have the color overridden to
colors 1, 15, 30, 150 for standards notes.
This is what I've got that seems to be working. Just want to see if my approach is correct.
Basically, I'll put a separate (progn statement for each instance of Mtext color. Is that the correct approach?
Code - Auto/Visual Lisp:
[Select]
if
setq
sel
ssget
"_X"
0
"mtext"
;;MTEXT
repeat
setq
int1
sslength
sel
setq
obj1
vlax
ename
vla-object
ssname
sel
setq
int1
1-
int1
progn
setq
txt
vla-get-textstring
obj1
while
vl-string-search
C1;"
txt
setq
txt
vl
string
subst
C256;"
C1;"
txt
vla-put-textstring
obj1 txt
progn
setq
txt1
vla-get-textstring
obj1
setq
txt1
vla-get-textstring
obj1
while
vl-string-search
C15;"
txt1
setq
txt1
vl
string
subst
C256;"
C15;"
txt1
vla-put-textstring
obj1 txt1
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Seagull
London, England
WWW
Re: Multiple MText entities with varying overridden colors back to Bylayer
Reply #1 on:
November 17, 2020, 12:34:12 PM »
Assuming that you are looking to remove the colour, have you considered using something like
this
Logged
Lee Mac Programming
Twitter
Exchange App Store
jlogan02
Bull Frog
Reply #2 on:
November 17, 2020, 01:37:02 PM »
Thanks Lee,
I should have said, the example is part of a larger routine that handles color changes for other entities.
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
