Hi All,
My first post to this board but I've been following it for a while. I've been looking for an improvement on a function that was previously posted here called "getblockenames." There were two versions. One in Vanilla Lisp and the other that sorted the list of blocks but contained some Visual Lisp.
I've reprinted it below:
(defun _getblockenames ( / d l n r )
(while (setq d (tblnext "BLOCK" (null d)))
(if (wcmatch (setq n (cdr (assoc 2 d))) "~`**")
(setq r (cons (tblobjname "BLOCK" n) r)
l (cons n l)
(mapcar '(lambda ( n ) (nth n r)) (vl-sort-i l '<))
Is there an easy way of writing the last line in Vanilla Lisp? My system isn't configured for Visual Lisp...
The problem appears to be associated with the function vl-sort-i.
