Author Topic: How to use Lee lisp as a subroutine "Lee Help Please"  (Read 2653 times)
HasanCAD
« on: November 13, 2020, 09:25:33 AM »
Hi All,
First of all thanks lee for your great lisps
I am using Align Text, MText or Attribute to Curve http://www.lee-mac.com/dtcurve.html
and I am want to use this lisp as a subroutine for text and curve selected.
I tried but in vane
« Last Edit: November 16, 2020, 10:58:05 PM by HasanCAD »
DEVITG
Re: How to use Lee lisp as a subroutine
« Reply #1 on: November 13, 2020, 05:52:53 PM »
Hi HasanCad , just make it a defun
(defun  DTCurve (/  ; --=={  Local Functions  }==--
And call it from your LISP by
(detcurve)
HasanCAD
« Reply #2 on: November 14, 2020, 08:48:41 AM »
(detcurve)
How to convert as
  1. (detcurve TEXT CURVE)
DEVITG
« Reply #3 on: November 14, 2020, 04:35:38 PM »
Hi HasannCad , it will be better to ask Lee Mac.
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: November 16, 2020, 06:18:44 PM »
Are you loading it if not can check if already loaded.
(if (not dtcurve)(load "dtcurve"))
Then (c:dtcurve) should work.
HasanCAD
« Reply #5 on: November 17, 2020, 10:26:50 PM »
I do not want to bother him
BIGAL
Re: How to use Lee lisp as a subroutine "Lee Help Please"
« Reply #6 on: November 18, 2020, 03:22:27 AM »
See image, sometimes you just have to wait a bit for an answer, I am sure if Lee can find time he will help.
HasanCAD
« Reply #7 on: December 11, 2020, 12:23:04 PM »
UP
MSTG007
« Reply #8 on: December 14, 2020, 07:23:08 AM »
Could you give a little more detail on how this would work within the routine you have created? I am kinda curious as well.
Civil3D 2020
HasanCAD
« Reply #9 on: December 30, 2020, 04:19:19 AM »
The lisp create a text has the line length but insert in middle of line
So I want to move text aligned to line.
