Ok, I have this code from Lee Mac that gets the block name from a cell, if the cell type is a block and is empty, it returns an error.
;; Get Table Cell Block - Lee Mac
;; Returns the Block Definition associated with a given table cell
(defun LM:blocknamefromtablecell ( tab row col / Block)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(eval
(list 'defun 'LM:getcellblock '( tab row col )
(and
(wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
(vlax-method-applicable-p tab 'getblocktablerecordid32)
(list 'vla-objectidtoobject32 (LM:acdoc) '(vla-getblocktablerecordid32 tab row col))
(list 'vla-objectidtoobject (LM:acdoc) '(vla-getblocktablerecordid tab row col))
(setq Block (LM:getcellblock tab row col))
(if Block
(vla-get-name Block)
nil
);End LM:blocknamefromtablecell
I thought I could use vla-isempty function to determine if the cell is empty, but it always returns that the cell is empty, even if it has a block in it.
(defun LM:acdoc nil
(LM:acdoc)
(if (not (vla-isempty tab row col))
(eval
(and
(if Block
nil
Anyone have any ideas on how to fix this so that it returns nil if there is no block? I suppose I could also write an error handler, but that doesn't feel like the right way to handle this, as I do need to check if the cell is truly empty for other reasons.
