Author Topic: Adding pre-routine into an existing routine  (Read 1190 times)
MSTG007
« on: October 13, 2020, 04:31:19 PM »
I am trying to modify Lee's Block Count Routine. To simply have the routine explode all dynamic blocks, then grab all the blocks on a layer.
I know I was just messing around with the following, but thought it would be easier just to place it in the beginning of his routine, but having a hard time figuring out where to put it.
(defun c:pre-run ()
(C:ExplodeDynamicBlocks)
(C:isoparking)
(C:Count)
(princ))
(defun C:ExplodeDynamicBlocks ( / ssAll drwordr)
  (setq ssAll (ssget "X" '((0 . "INSERT")(2 . "`*U*")))
   drwordr (getvar "draworderctl")
  (setvar "draworderctl" 0);supress warnings
  (sssetfirst nil ssAll) ;makes ssAll both gripped and selected.
  (c:burst)
  (setvar "draworderctl" drwordr));end defun
(defun c:isoparking ( / lay seliso )
   (setq lay "0,C-PRKG*")
   (if (setq seliso (ssget "_X" (list (cons 8 lay) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
       (command "_.layiso" seliso "")
(princ))
;;--------------=={ Count.lsp - Advanced Block Counter }==--------------;;
;;  This program enables the user to record the quantities of a         ;;
;;  selection or all standard or dynamic blocks in the working drawing. ;;
;;  The results of the block count may be displayed at the AutoCAD      ;;
;;  command-line, written to a Text or CSV file, or displayed in an     ;;
;;  AutoCAD Table, where available.                                     ;;
;;  Upon issuing the command syntax 'count' at the AutoCAD              ;;
;;  command-line, the user is prompted to make a selection of standard  ;;
;;  or dynamic blocks to be counted by the program. At this prompt,     ;;
;;  the user may right-click or press 'Enter' to automatically count    ;;
;;  all blocks in the drawing.                                          ;;
;;  Depending on the output setting, the results may then be printed    ;;
;;  to the AutoCAD command-line and displayed in the Text Window, or    ;;
;;  the user will be prompted to specify an insertion point for the     ;;
;;  table, or a filename & location for the Text or CSV output file.    ;;
;;  The program settings may be configured using the 'countsettings'    ;;
;;  command; this command will present the user with a dialog interface ;;
;;  through which the data output, table & file headings, displayed     ;;
;;  columns, sorting field & sort order may each be altered.            ;;
;;  Author:  Lee Mac, Copyright © 2014  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2010-06-05                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2010-06-06                                      ;;
;;  - Updated code to include Settings dialog.                          ;;
;;  - Added Undo Marks.                                                 ;;
;;  Version 1.2    -    2010-06-06                                      ;;
;;  - Fixed bug with 64-bit systems.                                    ;;
;;  Version 1.3    -    2011-03-02                                      ;;
;;  - Program completely rewritten.                                     ;;
;;  - Updated code to work without error on 64-bit systems by fixing    ;;
;;    bug with ObjectID subfunction - my thanks go to member 'Jeff M'   ;;
;;    at theSwamp.org forums for helping me solve this problem.         ;;
;;  - Added ability to write block count to Text/CSV Files.             ;;
;;  Version 1.4    -    2014-06-15                                      ;;
;;  Version 1.5    -    2015-06-07                                      ;;
;;  - Minor update to enable full compatibility with ZWCAD.             ;;
;;    (regeneratetablesuppressed property not available)                ;;
(setq
    count:version "1-5"
    count:defaults
        (out "tab")
        (tg1 "1")
        (tg2 "1")
        (tg3 "1")
        (ed1 "Block Data")
        (ed2 "Preview")
        (ed3 "Block Name")
        (ed4 "Count")
        (srt "blk")
        (ord "asc")
(defun count:fixdir ( dir )
    (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun count:getsavepath ( / tmp )
        (   (setq tmp (getvar 'roamablerootprefix))
            (strcat (count:fixdir tmp) "\\Support")
        (   (setq tmp (findfile "acad.pat"))
            (count:fixdir (vl-filename-directory tmp))
        (   (count:fixdir (vl-filename-directory (vl-filename-mktemp))))
(setq count:savepath (count:getsavepath) ;; Save path for DCL & Config files
      count:dclfname (strcat count:savepath "\\LMAC_count_V" count:version ".dcl")
      count:cfgfname (strcat count:savepath "\\LMAC_count_V" count:version ".cfg")
(defun c:count
        *error*
        all
        col
        des dir
        ed1 ed2 ed3 ed4
        fil fnm fun
        hgt
        idx ins
        lst
        ord out
        row
        sel srt
        tab tg1 tg2 tg3 tmp
        xrf
    (defun *error* ( msg )
        (if (= 'file (type des))
            (close des)
        (if (and (= 'vla-object (type tab))
                 (null (vlax-erased-p tab))
                 (= "AcDbTable" (vla-get-objectname tab))
                 (vlax-write-enabled-p tab)
                 (vlax-property-available-p tab 'regeneratetablesuppressed t)
            (vla-put-regeneratetablesuppressed tab :vlax-false)
        (if (and (= 'vla-object (type count:wshobject))
                 (not (vlax-object-released-p count:wshobject))
                (vlax-release-object count:wshobject)
                (setq count:wshobject nil)
        (count:endundo (count:acdoc))
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
    (if (not (findfile count:cfgfname))
        (count:writecfg count:cfgfname (mapcar 'cadr count:defaults))
    (count:readcfg count:cfgfname (mapcar 'car count:defaults))
    (foreach sym count:defaults
        (if (not (boundp (car sym))) (apply 'set sym))
    (if (and (= "tab" out) (not (vlax-method-applicable-p (vla-get-modelspace (count:acdoc)) 'addtable)))
        (setq out "txt")
    (count:startundo (count:acdoc))
    (while (setq tmp (tblnext "block" (null tmp)))
        (if (= 4 (logand 4 (cdr (assoc 70 tmp))))
            (setq xrf (vl-list* "," (cdr (assoc 2 tmp)) xrf))
    (if xrf
        (setq fil  (list '(0 . "INSERT") '(-4 . "<NOT") (cons 2 (apply 'strcat (cdr xrf))) '(-4 . "NOT>")))
        (setq fil '((0 . "INSERT")))
        (   (null (setq all (ssget "_X" fil)))
            (count:popup
                "No Blocks Found" 64
                (princ "No blocks were found in the active drawing.")
        (   (and (= "tab" out) (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer)))))))
            (count:popup
                "Current Layer Locked" 64
                (princ "Please unlock the current layer before using this program.")
        (   (progn
                (setvar 'nomutt 1)
                (princ "\nSelect blocks to count <all>: ")
                (setq sel
                        (   (null (setq sel (vl-catch-all-apply 'ssget (list fil))))
                            all
                        (   (null (vl-catch-all-error-p sel))
                            sel
                (setvar 'nomutt 0)
                (null sel)
        (   (or (= "com" out)
                (and (=  "tab" out) (setq ins (getpoint "\nSpecify point for table: ")))
                (and (/= "tab" out)
                    (setq fnm
                        (getfiled "Create Output File"
                                (   (and (setq dir (getenv "LMac\\countdir"))
                                         (vl-file-directory-p (setq dir (count:fixdir dir)))
                                    (strcat dir "\\")
                                (   (getvar 'dwgprefix))
                            out 1
Civil3D 2020
Greg B
  • Tell me a Joke!
Re: Adding pre-routine into an existing routine
« Reply #1 on: October 14, 2020, 08:39:55 AM »
I cannot tell if this is a compliment or a slam.
Either way it is quite funny!
(Sorry for the hijack)
