Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
replace text and mtext
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: replace text and mtext (Read 2476 times)
PM
Guest
on:
October 09, 2020, 11:01:32 AM »
Hi. I am using this lisp code to replace text and mtext. The problem is when i have a multy line mtext change only the first line and not all the mtext. Can any one help ?
Code - Auto/Visual Lisp:
[Select]
;;; By Muhammad Zubair Ahmad
;;; 26 March 2002
;;; REVISIONS
;;; 27 March 2002-- Minor bug fixes.
;;; DESCRIPTION
;;; This programme changes the text objects with selected text.
;;; The command is called with RT from the command line at which
;;; time the user is asked to select a text object whose tex is to be
;;; used as sampled:
;;; Select a Text Object:
;;; If a non-text object is selected the message
;;; ERROR:"xxxxx" selected...., Please Try Again!
;;; is displayed
;;; Select Destination Objects:
;;; Select objects:
;;; Successfull completed.
;;; Main function -- no arguments
Defun
RepText
nonText test Org Runn e e1 e2 t1 t2 txt sset lenth1
setq
nonText
nil
While
not
nonText
setq
e
car
entsel
\n
select text or Mtext: "
Setq
e1
entget
e
setq
t1
assoc
1
e1
setq
txt
cdr
assoc
0
e1
setq
nonText
or
equal
txt
"MTEXT"
equal
txt
"TEXT"
princ
\n
_____"
if
not
nonText
princ
strcat
\n
ERROR:
txt
selected...., Please Try Again!"
princ
\n
Princ
\n
Select Destination Objects:"
setq
sset
ssget
setq
test
0
Org
0
Runn
0
if
sset
progn
; then execute
setq
lenth
sslength
sset
while
test lenth
Setq
e2
entget
ssname
sset test
setq
txt
cdr
assoc
0
e2
if
or
txt
"TEXT"
txt
"MTEXT"
progn
; then execute
setq
t2
assoc
1
e2
setq
e2
subst
t1 t2 e2
entmod
e2
if
equal
e2 e1
setq
Org
1
Setq
Runn
1
; end progn
; end if
setq
test
test
1
; end while
if
and
Org
0
Runn
1
command
"erase"
e
princ
\n
Successfully completed. "
princ
; end progn
progn
; else show message
princ
\n
Nothing selected - command terminated"
princ
; end progn
; end if
; end function
;;; The C: function definition.
defun
c:RET
RepText
princ
\n
\t
RepText.lsp loaded. Start command with RET. (Prep'd by: Engr. Zubair)"
princ
Logged
Needs a day job
Re: replace text and mtext
Reply #1 on:
October 09, 2020, 11:05:09 AM »
Use vla-get-textstring .. long mtext strings store the text in multiple 3 dxf codes.
[Select]
3
fArial|b0|i0|c0|p34;sadfdsfdsfdsfsdfdsfds
P
P
pxi-3,l4,t4;1)
\t
ssssssss sdsdsd dssdsds sds dsd sd s sd ds ds dsd d dsdsdsdsdsdsd sds sd sd sd sd sdsdsd sd s d
P2)
\t
ssssssss sdsdsd dssdsds sds dsd sd s sd ds ds dsd d dsdsdsdsdsdsd sds sd sd sd sd sdsds"
3
"d sd s d
P3)
\t
P4)
\t
P5)
\t
ssssssss sdsdsd dssdsds sds dsd sd s "
3
"sd ds ds dsd d dsdsdsdsdsdsd sds sd sd sd sd sdsdsd sd s d
P6)
\t
P7)
\t
1
"d sd s d
P
pi0,l0,tz;
Pasassssssssssssssssssssssasas asas as as a sa sas as a sa as sas asasasasassas asa}"
Logged
PM
Guest
Reply #2 on:
October 09, 2020, 11:33:29 AM »
hi ronjonp. Can you fix it ?
Logged
Needs a day job
Reply #3 on:
October 09, 2020, 02:30:00 PM »
Quote from: PM on October 09, 2020, 11:33:29 AM
Why don't you take a stab at it first ?
Logged
jtoverka
Newt
Reply #4 on:
October 09, 2020, 02:38:36 PM »
Lee mac has a program called 'Batch Find & Replace Text'
http://www.lee-mac.com/bfind.html
If that doesn't satisfy your requirements, it at least has the code that can.
Logged
PM
Guest
Reply #5 on:
October 10, 2020, 03:19:59 AM »
Hi jtoverka. I ask if someone can update the code because some times i have a big mtext and i need to replace it with another .
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
