Author Topic: Relative paths  (Read 4556 times)
like_citrus
Relative paths
« on: October 08, 2020, 02:28:56 AM »
I found this code which batch converts DGN to DWG. It works (apart from not converting the first drawing, but that's another issue).
I'm trying to use relative folder paths for reasons of moving computer.
The critical parameters are "tx1", "tx2" and "tx3".
The LISP file which is set to autoload is on the same path as "tx1" which contains a list of the drawings to be converted.
(defun C:MicroStationToAutoCAD (/ fil tx1 tx2 tx3 tx4 tx5)
(setq tx1 "C:\\Drawing Conversion\\List.txt" ; File holding a list of MicroStation drawings to be imported
  tx2 "C:\\Drawing Conversion\\In\\" ; Input folder
  tx3 "C:\\Drawing Conversion\\Out\\" ; Output folder
  tx4 "Default" ; Drawing model name
(setvar "DGNIMPORTMODE" 1)
(setq fil (open tx1 "r")
  tx5 (read-line fil))
(while tx5
(if (wcmatch tx5 "*`.???")
(setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
(command "_UNDO" "_MARK"
     "_-DGNIMPORT" (strcat tx2 tx5) tx4 "" ""
     "_ZOOM" "_E"
     "._DELAY" 1000
     "_SAVEAS" "2007(LT2007)" (strcat tx3 tx5)
     "_UNDO" "_BACK"
(setq tx5 (read-line fil))
(close fil)
(command "_QUIT" "_Y")
Attempt at relative path:
(setq tx1 (load (findfile ".\\List.txt") nil)
  tx2 ((load (findfile ".\\In\\") nil)
  tx3 (load (findfile ".\\Out\\") nil)
kpblc
Re: Relative paths
« Reply #1 on: October 08, 2020, 06:00:11 AM »
I didn't check the code:
  1. (defun t1 (/ acad_obj adoc content folder handle input_subfolder item lst output_subfolder str sysvars file)
  2.   (setq folder "C:\\Drawing Conversion"
  3.         content "list.txt"
  4.         input_subfolder "In\\"
  5.         output_subfolder "Out\\"
  6.   ) ;_ end of setq
  7.   (if (and (findfile (setq folder (strcat (vl-string-right-trim folder "\\") "\\")))
  8.            (setq content (findfile (strcat folder content)))
  9.            (findfile (setq input_subfolder (strcat folder (vl-string-left-trim input_subfolder "\\.") "\\")))
  10.            (findfile (setq output_subfolder (strcat folder (vl-string-left-trim output_subfolder "\\.") "\\")))
  11.       ) ;_ end of and
  12.     (progn (setq handle (open content "r"))
  13.            (while (setq str (read-line handle)) (setq lst (cons lst str)))
  14.            (close handle)
  15.            (vla-startundomark
  16.              (vla-startundomark (setq adoc (vla-get-activedocument (setq acad_obj (vlax-get-acad-object)))))
  17.            ) ;_ end of vla-startundomark
  18.            (setq sysvars (mapcar (function (lambda (var / temp)
  19.                                              (if (setq temp (getvar (car var)))
  20.                                                (progn (if (cdr var)
  21.                                                         (setvar (car var) (cdr var))
  22.                                                       ) ;_ end of if
  23.                                                       (cons (car var) temp)
  24.                                                ) ;_ end of progn
  25.                                              ) ;_ end of if
  26.                                            ) ;_ end of lambda
  27.                                  ) ;_ end of function
  28.                                  '(("sysmon" . 0) ("cmdecho" . 0) ("menuecho" . 0) ("nomutt" . 1))
  29.                          ) ;_ end of mapcar
  30.            ) ;_ end of setq
  31.            (foreach item (reverse lst)
  32.              (if (wcmatch item "*`.???")
  33.                (setq item (substr item 1 (- (strlen item) 4)))
  34.              ) ;_ end of if
  35.              (if (findfile (setq file (strcat input_subfolder item)))
  36.                (progn (vl-cmdf "_.-dgnimport" file "Default")
  37.                       (vla-zoomall acad_obj)
  38.                       (vla-saveas adoc (strcat output_subfolder (vl-filename-base item) ".dwg") ac2007_dwg)
  39.                       ;; I think you have to erase all modelspace entities:
  40.                       ;; (vlax-for ent (vla-get-modelspace adoc) (vla-erase ent))
  41.                ) ;_ end of progn
  42.              ) ;_ end of if
  43.            ) ;_ end of foreach
  44.            (foreach item (vl-remove nil sysvars) (setvar (car item) (cdr item)))
  45.            (vla-endundomark adoc)
  46.     ) ;_ end of progn
  47.   ) ;_ end of if
  48.   (princ)
  49. ) ;_ end of defun
  50.
Sorry for my English.
like_citrus
Re: Relative paths
« Reply #2 on: October 08, 2020, 06:16:18 AM »
Thanks for responding kpblc.
I didn't frame my question properly.
So there would be no changes to the LISP file when moving computers. At the moment, in your code, you would have to input the path "C:\\Drawing Conversion".
This is because paths are relative to the LISP file and are in the same directory. The automatic load of the LISP file takes care of the path. Is this possible?
Not that I don't want to do it but will forget at the time and may or may not be able to decipher what has to be done.
I'll try your code at some stage, thanks for that.
ribarm
  • Marko Ribar, architect
Re: Relative paths
« Reply #3 on: October 08, 2020, 08:49:50 AM »
Man, I can't figure this syntax :
  1.            (vla-startundomark
  2.              (vla-startundomark (setq adoc (vla-get-activedocument (setq acad_obj (vlax-get-acad-object)))))
  3.            ) ;_ end of vla-startundomark
  4.
Why 2 (vla-startundomark)?
M.R. on Youtube
kpblc
Re: Relative paths
« Reply #4 on: October 08, 2020, 04:00:22 PM »
Ah, my mistake, sorry.
P.S. I wrote - I didn't check to code $;)
Hmmm... As fas as I know LISP can't define his loading path. You can automatically load lisp through at least 3 ways. How do you loading lisp? By Startup suite? By MNL? By acaddoc.lsp?
BIGAL
  • 40 + years of using Autocad
Re: Relative paths
« Reply #5 on: October 08, 2020, 07:12:21 PM »
4 is drag drop
kpblc
Re: Relative paths
« Reply #6 on: October 09, 2020, 01:00:13 AM »
D&D is autoload? :)
like_citrus
Re: Relative paths
« Reply #7 on: October 14, 2020, 09:25:02 PM »
Sorry for the late reply as I didn't get a notification for the messages.
To answer your question, my LISP is loaded through the Startup Suite.
Should I abandon this then? If there is no way to have relative paths?
PKENEWELL
Re: Relative paths
« Reply #8 on: October 15, 2020, 12:38:42 PM »
Like_Citrus:
when you call (findfile), it can only check the paths that are included in the "Support Paths" in options and in the currently opened drawing folder. In order to use the path you want - add it to the support paths in options, then when you call (findfile), just search for the file i.e. (findfile "list.txt").
From that - you can use (vl-filename-directory) to remove the file name from the full path returned from (findfile), then use (strcat) to combine it with the relative sub-directories.
Try this (untested):
  1. (defun C:MicroStationToAutoCAD (/ fil fn pth tx1 tx2 tx3 tx4 tx5)
  2.    (setq fn "list.txt"
  3.         ;; the path that the file is in must be in the support paths!
  4.          tx1 (findfile fn)
  5.          tx4 "Default"
  6.    )
  7.    (if (not tx1)
  8.       (princ "\nList file not found! Check the support paths. ")
  9.       (setq pth (vl-filename-directory tx1)
  10.             tx2 (strcat pth "\\in\\")
  11.             tx3 (strcat pth "\\out\\")
  12.       )
  13.    )
  14.    (setvar "DGNIMPORTMODE" 1)
  15.    (setq fil (open tx1 "r")
  16.            tx5 (read-line fil))
  17.    (while tx5
  18.       (if (wcmatch tx5 "*`.???")
  19.          (setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
  20.       )
  21.       (command "._UNDO" "_MARK"
  22.                       "._-DGNIMPORT" (strcat tx2 tx5) tx4 "" ""
  23.       )
  24.       (while (= (logand (getvar "cmdactive") 1) 1) (command ""))
  25.       (command "._ZOOM" "_E"
  26.                       "._DELAY" 1000
  27.                      "._SAVEAS" "2013(LT2013)" (strcat tx3 tx5)
  28.                      "._UNDO" "_BACK"
  29.       )
  30.       (setq tx5 (read-line fil))
  31.    )
  32.    (close fil)
  33.    (command "_QUIT" "_Y")
  34.    (princ)
  35. )
Note: Sorry - had to make some edits as I was using the wrong function - corrected.
« Last Edit: October 15, 2020, 12:52:58 PM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
like_citrus
Re: Relative paths
« Reply #9 on: October 15, 2020, 08:35:25 PM »
Thanks for providing the code.
I tried to run it after adding the path. The program was stuck though, whatever it was processing required a lot of memory. There was no error message in the command line.
The way I added the support path was: Tools, Options, Support File Search Path, Add. Added "C:\Drawing Conversion". Tried moving to the top, restarting, etc, no luck.
The only thing I could think of was adding "\\" after the "list.txt" using "strcat" ... but got an error message.
(setq pth (vl-filename-directory strcat tx1 "\\")
PKENEWELL
Re: Relative paths
« Reply #10 on: October 16, 2020, 10:55:23 AM »
Like_citrus: Yes - the code you tried to add would not work - both the syntax is incorrect and you were trying to add a folder slash to the end of a full path and filename.
  • (findfile fn) returns the full path and filename of "C:\\Drawing Conversion\\list.txt" because it searches the support paths.
  • (vl-filename-directory) strips the filename off, leaving "C:\\Drawing Conversion" (without backslashes)
  • Note that the variables tx2 and tx3 are adding in the end backslashes before the sub-folders: (strcat pth "\\in\\") & (strcat pth "\\out\\"). This returns "C:\\Drawing Conversion\\in\\" & "C:\\Drawing Conversion\\out\\" respectively.
Otherwise I cannot explain what it happening. Perhaps also add the "C:\Drawing Conversion\" folder to the "Trusted Locations"?
Also - did you re-start AutoCAD after adding the support path? EDIT - OK i see you did restart AutoCAD.
Sorry - I cannot test this program because I have no DGN files to import.
« Last Edit: October 16, 2020, 01:00:57 PM by PKENEWELL »
like_citrus
Re: Relative paths
« Reply #11 on: October 16, 2020, 09:24:22 PM »
That's OK, your understanding was quite good and well explained.
I did also try the C drive as a trusted path as well as other things, but no luck.
PKENEWELL
Re: Relative paths
« Reply #12 on: October 19, 2020, 12:40:05 PM »
Like_Citrus:
Could you send a few sample DGN files for me to test? Then I might be able to figure out what is going on.
like_citrus
Re: Relative paths
« Reply #13 on: October 19, 2020, 09:42:03 PM »
PKENEWELL, I tried to send a sample via PM but there was no option to attach.
Given I don't have ownership of the drawings, I can't post them online.
I did find a site which has sample DGN drawings available, please see link:
https://www.q-cad.com/samples/microstation-2d/microstation-2d-samples/
PKENEWELL
Re: Relative paths
« Reply #14 on: October 20, 2020, 09:35:07 AM »
Like Citrus:
Thanks for the link. I tried out the program with a list of all the sample files and it worked for me. NOTE - I think you need to add the sub-folders to the support paths as well as the main folder. EDIT: I tried it without adding the sub-paths and it worked still. Sorry - I still can't explain why it doesn't work for you.
Try this: I did some more clean up on the program and re-posted here. I added some error handling, some conditional to prevent error, removed the command scrolling and replaced with a status message.
  1. (defun C:MicroStationToAutoCAD (/ *error* fil fn pth oecho odgn resp tx1 tx2 tx3 tx4 tx5)
  2.
  3.    (defun *error* (msg)
  4.       (if (not (wcmatch (strcase msg T) "*break*,*cancel*,*quit*,*exit*"))
  5.               (princ (strcat "\nError: " msg "\n"))
  6.          (princ "\nProgram Aborted.\n")
  7.       )
  8.       (setvar "cmdecho" oecho)
  9.       (setvar "dgnimportmode" odgn)
  10.    )
  11.
  12.    (setq fn "list.txt"
  13.          tx1 (findfile fn)
  14.          tx4 "Default"
  15.          oecho (getvar "cmdecho")
  16.          odgn (getvar "dgnimportmode")
  17.    )
  18.    (setvar "cmdecho" 0)
  19.    (setvar "dgnimportmode" 1)
  20.    (if (not tx1)
  21.       (princ "\nList file not found! Check the support paths. ")
  22.       (setq pth (vl-filename-directory tx1)
  23.             tx2 (strcat pth "\\in\\")
  24.             tx3 (strcat pth "\\out\\")
  25.       )
  26.    )
  27.    (if pth
  28.       (progn
  29.         (setq fil (open tx1 "r")
  30.                    tx5 (read-line fil)
  31.          )
  32.          (princ "\nConverting Files =")
  33.         (while tx5
  34.                 (if (wcmatch tx5 "*`.???")
  35.                         (setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
  36.                 )
  37.                 (command "._UNDO" "_MARK"
  38.                      "._-DGNIMPORT" (strcat tx2 tx5) tx4 "" ""
  39.             )
  40.             (while (= (logand (getvar "cmdactive") 1) 1) (command ""))
  41.             (command "._ZOOM" "_E"
  42.                      "._DELAY" 1000
  43.                      "._SAVEAS" "2013(LT2013)" (strcat tx3 tx5)
  44.                      "._UNDO" "_BACK"
  45.             )
  46.             (if (= (logand (getvar "cmdactive") 1) 1)(Alert "Something Did not process correctly in this drawing.\nVerify the command sequence."))
  47.             (princ "=")
  48.                 (setq tx5 (read-line fil))
  49.         )
  50.         (close fil)
  51.          (princ " Conversion Completed! ")
  52.          (initget "Yes No")
  53.          (if (or (= (setq resp (getkword "\nDo you want to quit AutoCAD? [Yes/No] <Yes>: ")) "Yes")(= resp ""))
  54.           (command "_QUIT" "_Y")
  55.          )
  56.       )
  57.    )
  58.    (setvar "cmdecho" oecho)
  59.    (setvar "dgnimportmode" odgn)
  60.         (princ)
  61. )
  62.
« Last Edit: October 20, 2020, 10:53:45 AM by PKENEWELL »
