Author Topic: Layers LISP routine  (Read 4350 times)
Re: Layers LISP routine
« Reply #15 on: October 08, 2020, 11:53:14 AM »
RJP you are AWESOME!!!!!!!!!
Fun fact: The swamp has 6110 registered members. RJP was the 5th, registering the same month the swamp was born, 17 years ago.
My how time flies! How did you find the stat that I was the 5th registered user?  :wideeyed2:
« Reply #16 on: October 08, 2020, 12:22:22 PM »
If you go to the member list and sort by the date registered but that isn't actually your ID. You were actually the 13th member to register. I cannot show you that list because it has IPs and emails and such.
In the beginning we had two forums: theSwamp and bigSwamp (big was first by quite a while). And while we were setting up the server, at Mark's house, I was behind by a few days getting my account set up at theSwamp. We planned on moving the database over from bigSwamp over to create theSwamp but I don't think we ever did.
« Reply #17 on: October 08, 2020, 01:53:03 PM »
